[Swift-devel] 0.93 problem: Fwd: amwg-swift
    Michael Wilde
    wilde at mcs.anl.gov
    Thu Sep  1 17:32:20 CDT 2011
This issue reported by Sheri w the Parvis amwg script looks a lot like
what Jon reported earlier today. Mihael, Justin, David, Jon: can you
investigate? Jon, can you repro the problem and send in a jstack?
---------- Forwarded message ----------
Date: Thu, 1 Sep 2011 16:20:21 -0500
Subject: Fwd: amwg-swift
To: Michael Wilde <wilde at mcs.anl.gov>
Cc: Andrew Mai <mai at ucar.edu>
Hi Mike,
Sorry to bother you with this, but if you have time within the next
1/2 hour -45 minutes can you check on a amwg-swift run Andy is trying
on mirage2.ucar.edu?  He lists all the directories below.  It's trying
to run, but all swift is doing is ...
Progress:  time: Thu, 01 Sep 2011 15:17:25 -0600  Initializing:450
Selecting site:12  Stage in:8
It's been repeating "Initializing:450  Selecting site:12  Stage in:8"
for the last 40 minutes.
He's using swift 0.93.  Is this a swift concurrency issue?
-Sheri
Begin forwarded message:
> From: Andrew Mai <mai at ucar.edu>
> Date: September 1, 2011 4:09:05 PM CDT
> To: Sheri Mickelson <mickelso at mcs.anl.gov>
> Subject: Re: amwg-swift
> On 09/01/2011 02:59 PM, Sheri Mickelson wrote:
>> That's not normal.
> I have to go to a CSEG meeting. I will leave it running on mirage2.
> You can log in and watch it run, if you want to. Relevant directories:
> work dir   : /glade/scratch/mai/swift-workdirectory/
> amwg_stats-20110901-1440-ujv4b5z8
> script dir : /glade/home/mai/AMWG_diag/swift
> code base  : /fis/cgd/cms/amwg/amwg_diagnostics_swift
> output dir : /glade/scratch/mai/output-SO1
> Andy
Sent from my mobile device
