[Swift-devel] [Swift-user] gram on ranger
David Kelly davidk at ci.uchicago.edu
Fri Oct 28 12:41:02 CDT 2011
Just to clarify - when coasters is being used, count represents the number of coaster blocks? Then to get the number of cores to request, I should use count*workersPerNode?
What about in the case where coasters is not used?
----- Original Message -----
> From: "Mihael Hategan" <hategan at mcs.anl.gov>
> To: "David Kelly" <davidk at ci.uchicago.edu>
> Cc: "Anjali Raja" <anjraja at gmail.com>, "Swift Devel" <swift-devel at ci.uchicago.edu>, "Swift User"
> <swift-user at ci.uchicago.edu>, "Ketan Maheshwari" <ketancmaheshwari at gmail.com>
> Sent: Thursday, October 20, 2011 9:08:46 PM
> Subject: Re: [Swift-devel] [Swift-user] gram on ranger
> On Thu, 2011-10-20 at 21:03 -0500, David Kelly wrote:
> > Yep, this is using coasters
> Then no. Count is whatever the block allocation algorithm decides it
> should be.
> > > > Should count=32 in the second case? Am I misunderstanding what
> > > > 'count' is? Is there any way to get the exact number of
> > > > applications?
> > > Coasters?
