[Swift-devel] [Swift-user] gram on ranger
Michael Wilde
wilde at mcs.anl.gov
Fri Oct 21 08:00:44 CDT 2011
David, "whatever the block allocation algorithm decides it should be" is the box-packing algorithm thats mentioned in the UCC 2012 paper and which we discussed late yesterday afternoon.
We should document it in the User Guide in an elaborated Coaster section.
I suggested to David that he add (at least temporarily pending discussion) the coresPerNode site attribute so that - at least for SGE - the provider can set the correct value in the core-count field of the SGE submit file "pe" attribute.
This seems to me to be necessary: we dont want to set the pe core count using jobsPerNode, as users on occasion need to set jobsPerNode to be higher or lower than the number of cores on the node.
- Mike
----- Original Message -----
> From: "Mihael Hategan" <hategan at mcs.anl.gov>
> To: "David Kelly" <davidk at ci.uchicago.edu>
> Cc: "Anjali Raja" <anjraja at gmail.com>, "Swift Devel" <swift-devel at ci.uchicago.edu>, "Swift User"
> <swift-user at ci.uchicago.edu>
> Sent: Thursday, October 20, 2011 9:08:46 PM
> Subject: Re: [Swift-devel] [Swift-user] gram on ranger
> On Thu, 2011-10-20 at 21:03 -0500, David Kelly wrote:
> > Yep, this is using coasters
> Then no. Count is whatever the block allocation algorithm decides it
> should be.
> > > > Should count=32 in the second case? Am I misunderstanding what
> > > > 'count' is? Is there any way to get the exact number of
> > > > applications?
> > > Coasters?
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
