[Swift-devel] [Swift-user] gram on ranger
Justin M Wozniak wozniak at mcs.anl.gov
Fri Oct 28 13:02:35 CDT 2011
I think count is the number of processes.  PBSExecutor uses it, that may
be a good place to look.  In the Coasters context, I think it is the
number of invocations of worker.pl .
On Fri, 28 Oct 2011, David Kelly wrote:
> Just to clarify - when coasters is being used, count represents the
> number of coaster blocks? Then to get the number of cores to request, I
> should use count*workersPerNode?
> What about in the case where coasters is not used?
>> From: "Mihael Hategan" <hategan at mcs.anl.gov>
>> To: "David Kelly" <davidk at ci.uchicago.edu>
>> Cc: "Anjali Raja" <anjraja at gmail.com>, "Swift Devel" <swift-devel at ci.uchicago.edu>, "Swift User"
>> <swift-user at ci.uchicago.edu>, "Ketan Maheshwari" <ketancmaheshwari at gmail.com>
>> Sent: Thursday, October 20, 2011 9:08:46 PM
>> Subject: Re: [Swift-devel] [Swift-user] gram on ranger
>> On Thu, 2011-10-20 at 21:03 -0500, David Kelly wrote:
>>> Yep, this is using coasters
>> Then no. Count is whatever the block allocation algorithm decides it
>> should be.
>>>>> Should count=32 in the second case? Am I misunderstanding what
>>>>> 'count' is? Is there any way to get the exact number of
>>>>> applications?
>>>> Coasters?
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Justin M Wozniak
