[Swift-devel] persistent coasters and data staging
Mihael Hategan hategan at mcs.anl.gov
Sat Oct 8 14:53:46 CDT 2011
On Fri, 2011-10-07 at 15:52 -0500, David Kelly wrote:
> The exception I'm seeing is:
> Caused by: org.globus.cog.abstraction.impl.common.execution.JobException: Job failed with an exit code of 521
> It stops after about 10 minutes or so. The scripts and logs are on /autonfs/gpfs-pads/projects/CI-CCR000013/davidk/coaster-stress-tests
I don't see logs there.
