[Swift-devel] persistent coasters and data staging
David Kelly davidk at ci.uchicago.edu
Sat Oct 8 19:19:40 CDT 2011
Sorry about that, not sure what happened there. Check /autonfs/gpfs-pads/projects/CI-CCR000013/davidk/test2. I modified this test so that the parallelism is better: 8 jobs per node, 10 machines, 80 active tasks at a time. This run used 500 files X 10 megs but seems to have similarly failed. The coaster logs are in logs/.
David
----- Original Message -----
> From: "Mihael Hategan" <hategan at mcs.anl.gov>
> To: "David Kelly" <davidk at ci.uchicago.edu>
> Cc: "Swift Devel" <swift-devel at ci.uchicago.edu>, "Michael Wilde" <wilde at mcs.anl.gov>
> Sent: Saturday, October 8, 2011 2:53:46 PM
> Subject: Re: [Swift-devel] persistent coasters and data staging
> On Fri, 2011-10-07 at 15:52 -0500, David Kelly wrote:
> > The exception I'm seeing is:
> > Caused by:
> > org.globus.cog.abstraction.impl.common.execution.JobException: Job
> > failed with an exit code of 521
> > It stops after about 10 minutes or so. The scripts and logs are on
> > /autonfs/gpfs-pads/projects/CI-CCR000013/davidk/coaster-stress-tests
> I don't see logs there.
