[Swift-devel] SGE's qstat output parsing failure
    Luiz Gadelha
    lgadelha at lncc.br
    Wed Nov 23 12:46:25 CST 2011
I attached the qstat output as a text file, it's easier too see its format there than in the previous message body.
On Nov 23, 2011, at 4:27 PM, Luiz Gadelha wrote:
> Hi,
> There is a small bug in the parsing of SGE's qstat output lines. For the following qstat output:
> job-ID  prior   name       user         state submit/start at     queue                          slots ja-task-ID
> 543309 0.50500 null       lgadelha     r     11/22/2011 14:40:38 linux.q at cmm11bl5.hpc.lncc.br       1
> 543310 0.50500 null       lgadelha     r     11/22/2011 14:40:38 linux.q at cmm11bl5.hpc.lncc.br       1
> QueuePoller incorrectly assumes that the job identifier is in the same position as "job-ID" in the header, which is not the case above, where it finds a space character and returns an empty string as the job identifier, Swift fails with a "Failed to parse qstat line" message. The attached log file is from a simple test script run that presents this problem.
> The attached patch fixed the problem in my environment.
> Regards,
> Luiz
> Luiz Gadelha
> http://www.lncc.br/~lgadelha
> <openssl-20111122-1725-07cmqx2a.log.gz>
> <sge_fix.diff>
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Luiz Gadelha
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20111123/4a9ebaca/attachment.txt>
