[Swift-devel] SGE's qstat output parsing failure
David Kelly davidk at ci.uchicago.edu
Wed Nov 23 12:59:49 CST 2011
Thanks Luiz. I've seen some similar issues with 0.92 when parsing qstat output. qstat output tends to change between versions which can cause parsing problems like this. For 0.93, we will be using the XML output to help standardize things a bit.
David
----- Original Message -----
> From: "Luiz Gadelha" <lgadelha at lncc.br>
> To: "Swift Devel" <swift-devel at ci.uchicago.edu>
> Sent: Wednesday, November 23, 2011 12:27:03 PM
> Subject: [Swift-devel] SGE's qstat output parsing failure
> Hi,
> There is a small bug in the parsing of SGE's qstat output lines. For
> the following qstat output:
> job-ID prior name user state submit/start at queue slots ja-task-ID
> 543309 0.50500 null lgadelha r 11/22/2011 14:40:38
> linux.q at cmm11bl5.hpc.lncc.br 1
> 543310 0.50500 null lgadelha r 11/22/2011 14:40:38
> QueuePoller incorrectly assumes that the job identifier is in the same
> position as "job-ID" in the header, which is not the case above, where
> it finds a space character and returns an empty string as the job
> identifier, Swift fails with a "Failed to parse qstat line" message.
> The attached log file is from a simple test script run that presents
> this problem.
> The attached patch fixed the problem in my environment.
> Regards,
> Luiz
> Luiz Gadelha
> http://www.lncc.br/~lgadelha
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
