[Swift-devel] SGE's qstat output parsing failure
Luiz Gadelha
lgadelha at lncc.br
Wed Nov 23 12:27:03 CST 2011
There is a small bug in the parsing of SGE's qstat output lines. For the following qstat output:
job-ID prior name user state submit/start at queue slots ja-task-ID
543309 0.50500 null lgadelha r 11/22/2011 14:40:38 linux.q at cmm11bl5.hpc.lncc.br 1
543310 0.50500 null lgadelha r 11/22/2011 14:40:38 linux.q at cmm11bl5.hpc.lncc.br 1
QueuePoller incorrectly assumes that the job identifier is in the same position as "job-ID" in the header, which is not the case above, where it finds a space character and returns an empty string as the job identifier, Swift fails with a "Failed to parse qstat line" message. The attached log file is from a simple test script run that presents this problem.
The attached patch fixed the problem in my environment.
Luiz
Luiz Gadelha
http://www.lncc.br/~lgadelha
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20111123/611ff89a/attachment.bin>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20111123/611ff89a/attachment.obj>
