[Swift-devel] Error while parsing XML
    Ketan Maheshwari
    ketancmaheshwari at gmail.com
    Sun Nov 20 11:02:02 CST 2011
I am seeing this error message at runtime on the SCEC workflow:
Progress:  time: Sun, 20 Nov 2011 10:20:51 -0600  Active:2  Finished
successfully:4
[Fatal Error] :-1:-1: Premature end of file.
org.xml.sax.SAXParseException: Premature end of file.
        at org.apache.xerces.parsers.DOMParser.parse(Unknown Source)
        at org.apache.xerces.jaxp.DocumentBuilderImpl.parse(Unknown Source)
        at javax.xml.parsers.DocumentBuilder.parse(DocumentBuilder.java:124)
        at
org.globus.cog.abstraction.impl.scheduler.sge.QueuePoller.processStdout(QueuePoller.java:191)
        at
org.globus.cog.abstraction.impl.scheduler.common.AbstractQueuePoller.pollQueue(AbstractQueuePoller.java:170)
        at
org.globus.cog.abstraction.impl.scheduler.common.AbstractQueuePoller.run(AbstractQueuePoller.java:82)
        at java.lang.Thread.run(Thread.java:619)
Progress:  time: Sun, 20 Nov 2011 10:21:02 -0600  Active:1  Finished
successfully:4 Failed but can retry:1
Exception in simsgt:
Arguments: [TEST, processed/gridout_TEST, processed/TEST.modelbox,
processed/TEST.fdloc, processed/TEST.cordfile, x]
Host: SGE
Directory: presgt-20111120-0852-n6cze3l8/jobs/d/simsgt-dlogn1jk
stderr.txt:
stdout.txt:
Caused by: java.io.IOException: Error while parsing XML
processed/TEST.fdloc, processed/TEST.cordfile, y]
Host: SGE
Directory: presgt-20111120-0852-n6cze3l8/jobs/e/simsgt-elogn1jk
stderr.txt:
stdout.txt:
Final status:  time: Sun, 20 Nov 2011 10:21:02 -0600  Failed:2  Finished
successfully:4
The following errors have occurred:
1. java.io.IOException: Error while parsing XML (2 times)
The log is: http://www.mcs.anl.gov/~ketan/presgt-20111120-0852-n6cze3l8.log
It shows the same error message at the end of the log. Does anyone else see
this?
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20111120/a4339891/attachment.html>
