[Swift-devel] CDM Tests
Michael Wilde wilde at mcs.anl.gov
Mon Nov 14 13:21:45 CST 2011
Ketan,
I thought your initial email stated that the 4 cases of relative path names "worked".  But this latter comment indicates that there is some kind of problem even in the relative cases.
Can you clarify?
- Mike
----- Original Message -----
> From: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>
> To: "Justin M Wozniak" <wozniak at mcs.anl.gov>
> Cc: "Michael Wilde" <wilde at mcs.anl.gov>, "Swift Devel" <swift-devel at ci.uchicago.edu>
> Sent: Monday, November 14, 2011 11:01:35 AM
> Subject: Re: [Swift-devel] CDM Tests
> Given the CDM's support for relative pathnames, I would expect the
> case of relative inputs, relative outputs would succeed irrespective
> of config. However, from the tests, it seems that the config option is
> overriding CDM directives.
> On Mon, Nov 14, 2011 at 12:44 PM, Justin M Wozniak <
> wozniak at mcs.anl.gov > wrote:
> CDM DIRECT does not currently support absolute path names. I think we
> could provide something simple like "" for the field, as you suggest.
> On Mon, 14 Nov 2011, Michael Wilde wrote:
> > I would expect that for absolute path mappings, the user would
> > specify
> > either :: or "/" as the path in the CDM DIRECT pattern. In other
> > words,
> > the user is saying "I have mapped the object to an absolute path
> > name,
> > and I want the app to get exactly this name". Hence I think that the
> > best "location" field for a DIRECT rule is null ("").
> > Justin, can you clarify what the code expects for this case?
> > - Mike
> >> From: "Jonathan Monette" < jonmon at mcs.anl.gov >
> >> To: "Michael Wilde" < wilde at mcs.anl.gov >
> >> Cc: "Ketan Maheshwari" < ketancmaheshwari at gmail.com >, "Swift
> >> Devel" < swift-devel at ci.uchicago.edu >
> >> Sent: Monday, November 14, 2011 9:13:01 AM
> >> I couldn't tell from the excel(using my phone) but what was
> >> absolute?
> >> If I am not mistaken what CDM does is takes the path that is
> >> specified
> >> in the CDM file(which should be absolute) and appends the file path
> >> that is used in the swift script to it(which should be relative).
> >> So
> >> if they are both absolute I would expect it to fail.
> >> On Nov 14, 2011, at 10:56 AM, Michael Wilde < wilde at mcs.anl.gov >
> >> wrote:
> >>> Thanks, Ketan - very nice tests and summary document.
> >>> I should point out for those that didn't open the doc: the 4 tests
> >>> with absolute pathnames are failing.
> >>> Ketan, can you work with Justin to see if this is a bug, or if the
> >>> CDM directive needs to be coded differently for absolute paths?
> >>> Then
> >>> please test a fix, and as we discussed adapt the tests with
> >>> annotations to enhance the User Guide section on CDM.
> >>> - Mike
> >>>> From: "Ketan Maheshwari" < ketancmaheshwari at gmail.com >
> >>>> To: "Swift Devel" < swift-devel at ci.uchicago.edu >
> >>>> Sent: Monday, November 14, 2011 8:13:48 AM
> >>>> Subject: [Swift-devel] CDM Tests
> >>>> Hello,
> >>>> I had a discussion with Mike about testing the CDM behavior for
> >>>> the
> >>>> following cases:
> >>>> 1. full versus relative paths for input
> >>>> 2. full versus relative paths for output
> >>>> 3. relative versus absolute option in config property:
> >>>> wrapper.invocation.mode
> >>>> In this regard, I made 8 tests for all the above combinations. I
> >>>> used
> >>>> simple local provider in this first set of tests.
> >>>> From the tests it seems that when specifying the relative option
> >>>> on
> >>>> the config for wrapper.invocation.mode property the script works
> >>>> regardless of the paths of input/output.
> >>>> A detailed result with stdout, and paths to logs can be found
> >>>> here:
> >>>> https://docs.google.com/spreadsheet/ccc?key=0AmvYSwENKFY9dG44V2VjRXJlUmZLNG9saERFeWZDcUE
> >>>> The tests are in my CI dir: /home/ketan/cdm_tests
> >>>> Regards, --
> >>>> Ketan
> >>>> _______________________________________________
> >>>> Swift-devel mailing list
> >>>> Swift-devel at ci.uchicago.edu
> >>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> >>> Michael Wilde
> >>> Computation Institute, University of Chicago
> >>> Mathematics and Computer Science Division
> >>> Argonne National Laboratory
> Justin M Wozniak
> Ketan
Michael Wilde
