[Swift-devel] CDM Tests
Ketan Maheshwari
ketancmaheshwari at gmail.com
Mon Nov 14 13:01:35 CST 2011
Given the CDM's support for relative pathnames, I would expect the case of
relative inputs, relative outputs would succeed irrespective of config.
However, from the tests, it seems that the config option is overriding CDM
directives.
On Mon, Nov 14, 2011 at 12:44 PM, Justin M Wozniak <wozniak at mcs.anl.gov>wrote:
> CDM DIRECT does not currently support absolute path names. I think we
> could provide something simple like "" for the field, as you suggest.
> On Mon, 14 Nov 2011, Michael Wilde wrote:
> > I would expect that for absolute path mappings, the user would specify
> > either :: or "/" as the path in the CDM DIRECT pattern. In other words,
> > the user is saying "I have mapped the object to an absolute path name,
> > and I want the app to get exactly this name". Hence I think that the
> > best "location" field for a DIRECT rule is null ("").
> > Justin, can you clarify what the code expects for this case?
> > - Mike
> > ----- Original Message -----
> >> From: "Jonathan Monette" <jonmon at mcs.anl.gov>
> >> To: "Michael Wilde" <wilde at mcs.anl.gov>
> >> Cc: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>, "Swift Devel" <
> swift-devel at ci.uchicago.edu>
> >> Sent: Monday, November 14, 2011 9:13:01 AM
> >> Subject: Re: [Swift-devel] CDM Tests
> >> I couldn't tell from the excel(using my phone) but what was absolute?
> >> If I am not mistaken what CDM does is takes the path that is specified
> >> in the CDM file(which should be absolute) and appends the file path
> >> that is used in the swift script to it(which should be relative). So
> >> if they are both absolute I would expect it to fail.
> >> On Nov 14, 2011, at 10:56 AM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> >>> Thanks, Ketan - very nice tests and summary document.
> >>> I should point out for those that didn't open the doc: the 4 tests
> >>> with absolute pathnames are failing.
> >>> Ketan, can you work with Justin to see if this is a bug, or if the
> >>> CDM directive needs to be coded differently for absolute paths? Then
> >>> please test a fix, and as we discussed adapt the tests with
> >>> annotations to enhance the User Guide section on CDM.
> >>> - Mike
> >>>> From: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>
> >>>> To: "Swift Devel" <swift-devel at ci.uchicago.edu>
> >>>> Sent: Monday, November 14, 2011 8:13:48 AM
> >>>> Subject: [Swift-devel] CDM Tests
> >>>> Hello,
> >>>> I had a discussion with Mike about testing the CDM behavior for the
> >>>> following cases:
> >>>> 1. full versus relative paths for input
> >>>> 2. full versus relative paths for output
> >>>> 3. relative versus absolute option in config property:
> >>>> wrapper.invocation.mode
> >>>> In this regard, I made 8 tests for all the above combinations. I
> >>>> used
> >>>> simple local provider in this first set of tests.
> >>>> From the tests it seems that when specifying the relative option on
> >>>> the config for wrapper.invocation.mode property the script works
> >>>> regardless of the paths of input/output.
> >>>> A detailed result with stdout, and paths to logs can be found here:
> https://docs.google.com/spreadsheet/ccc?key=0AmvYSwENKFY9dG44V2VjRXJlUmZLNG9saERFeWZDcUE
> >>>> The tests are in my CI dir: /home/ketan/cdm_tests
> >>>> Regards, --
> >>>> Ketan
> >>>> _______________________________________________
> >>>> Swift-devel mailing list
> >>>> Swift-devel at ci.uchicago.edu
> >>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> >>> Michael Wilde
> >>> Computation Institute, University of Chicago
> >>> Mathematics and Computer Science Division
> >>> Argonne National Laboratory
> Justin M Wozniak
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20111114/9401da53/attachment.html>
