[Swift-devel] CDM Tests
    Justin M Wozniak
    wozniak at mcs.anl.gov
    Mon Nov 14 12:44:36 CST 2011
CDM DIRECT does not currently support absolute path names.  I think we
could provide something simple like "" for the field, as you suggest.
On Mon, 14 Nov 2011, Michael Wilde wrote:
> I would expect that for absolute path mappings, the user would specify
> either :: or "/" as the path in the CDM DIRECT pattern. In other words,
> the user is saying "I have mapped the object to an absolute path name,
> and I want the app to get exactly this name". Hence I think that the
> best "location" field for a DIRECT rule is null ("").
> Justin, can you clarify what the code expects for this case?
> - Mike
>> From: "Jonathan Monette" <jonmon at mcs.anl.gov>
>> To: "Michael Wilde" <wilde at mcs.anl.gov>
>> Cc: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>, "Swift Devel" <swift-devel at ci.uchicago.edu>
>> Sent: Monday, November 14, 2011 9:13:01 AM
>> Subject: Re: [Swift-devel] CDM Tests
>> I couldn't tell from the excel(using my phone) but what was absolute?
>> If I am not mistaken what CDM does is takes the path that is specified
>> in the CDM file(which should be absolute) and appends the file path
>> that is used in the swift script to it(which should be relative). So
>> if they are both absolute I would expect it to fail.
>> On Nov 14, 2011, at 10:56 AM, Michael Wilde <wilde at mcs.anl.gov> wrote:
>>> Thanks, Ketan - very nice tests and summary document.
>>> I should point out for those that didn't open the doc: the 4 tests
>>> with absolute pathnames are failing.
>>> Ketan, can you work with Justin to see if this is a bug, or if the
>>> CDM directive needs to be coded differently for absolute paths? Then
>>> please test a fix, and as we discussed adapt the tests with
>>> annotations to enhance the User Guide section on CDM.
>>> - Mike
>>>> From: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>
>>>> To: "Swift Devel" <swift-devel at ci.uchicago.edu>
>>>> Sent: Monday, November 14, 2011 8:13:48 AM
>>>> Subject: [Swift-devel] CDM Tests
>>>> Hello,
>>>> I had a discussion with Mike about testing the CDM behavior for the
>>>> following cases:
>>>> 1. full versus relative paths for input
>>>> 2. full versus relative paths for output
>>>> 3. relative versus absolute option in config property:
>>>> wrapper.invocation.mode
>>>> In this regard, I made 8 tests for all the above combinations. I
>>>> used
>>>> simple local provider in this first set of tests.
>>>> From the tests it seems that when specifying the relative option on
>>>> the config for wrapper.invocation.mode property the script works
>>>> regardless of the paths of input/output.
>>>> A detailed result with stdout, and paths to logs can be found here:
>>>> https://docs.google.com/spreadsheet/ccc?key=0AmvYSwENKFY9dG44V2VjRXJlUmZLNG9saERFeWZDcUE
>>>> The tests are in my CI dir: /home/ketan/cdm_tests
>>>> Regards, --
>>>> Ketan
>>>> _______________________________________________
>>>> Swift-devel mailing list
>>>> Swift-devel at ci.uchicago.edu
>>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>>> Michael Wilde
>>> Computation Institute, University of Chicago
>>> Mathematics and Computer Science Division
>>> Argonne National Laboratory
Justin M Wozniak
