[Swift-devel] CDM Tests
    Michael Wilde
    wilde at mcs.anl.gov
    Mon Nov 14 12:28:18 CST 2011
I would expect that for absolute path mappings, the user would specify either :: or "/" as the path in the CDM DIRECT pattern. In other words, the user is saying "I have mapped the object to an absolute path name, and I want the app to get exactly this name". Hence I think that the best "location" field for a DIRECT rule is null ("").
Justin, can you clarify what the code expects for this case?
- Mike
----- Original Message -----
> From: "Jonathan Monette" <jonmon at mcs.anl.gov>
> To: "Michael Wilde" <wilde at mcs.anl.gov>
> Cc: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>, "Swift Devel" <swift-devel at ci.uchicago.edu>
> Sent: Monday, November 14, 2011 9:13:01 AM
> Subject: Re: [Swift-devel] CDM Tests
> I couldn't tell from the excel(using my phone) but what was absolute?
> If I am not mistaken what CDM does is takes the path that is specified
> in the CDM file(which should be absolute) and appends the file path
> that is used in the swift script to it(which should be relative). So
> if they are both absolute I would expect it to fail.
> On Nov 14, 2011, at 10:56 AM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> > Thanks, Ketan - very nice tests and summary document.
> > I should point out for those that didn't open the doc: the 4 tests
> > with absolute pathnames are failing.
> > Ketan, can you work with Justin to see if this is a bug, or if the
> > CDM directive needs to be coded differently for absolute paths? Then
> > please test a fix, and as we discussed adapt the tests with
> > annotations to enhance the User Guide section on CDM.
> > - Mike
> >> From: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>
> >> To: "Swift Devel" <swift-devel at ci.uchicago.edu>
> >> Sent: Monday, November 14, 2011 8:13:48 AM
> >> Subject: [Swift-devel] CDM Tests
> >> Hello,
> >> I had a discussion with Mike about testing the CDM behavior for the
> >> following cases:
> >> 1. full versus relative paths for input
> >> 2. full versus relative paths for output
> >> 3. relative versus absolute option in config property:
> >> wrapper.invocation.mode
> >> In this regard, I made 8 tests for all the above combinations. I
> >> used
> >> simple local provider in this first set of tests.
> >> From the tests it seems that when specifying the relative option on
> >> the config for wrapper.invocation.mode property the script works
> >> regardless of the paths of input/output.
> >> A detailed result with stdout, and paths to logs can be found here:
> >> https://docs.google.com/spreadsheet/ccc?key=0AmvYSwENKFY9dG44V2VjRXJlUmZLNG9saERFeWZDcUE
> >> The tests are in my CI dir: /home/ketan/cdm_tests
> >> Regards, --
> >> Ketan
> >> _______________________________________________
> >> Swift-devel mailing list
> >> Swift-devel at ci.uchicago.edu
> >> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> > Michael Wilde
> > Computation Institute, University of Chicago
> > Mathematics and Computer Science Division
> > Argonne National Laboratory
Michael Wilde
