[Swift-devel] DataNode.toString()
    Mihael Hategan
    hategan at mcs.anl.gov
    Wed May 25 15:03:11 CDT 2011
data.toString() had this hack that if there was a value, it would return
that value (which was assumed useable in fuctional code), otherwise it
would return the cryptic stuff.
So depending on whether we want the old behavior or not is trace and
tracef, I can add a .getValue() where needed.
So do we?
Mihael
On Wed, 2011-05-25 at 14:53 -0500, Justin M Wozniak wrote:
> Ok, just so we're all on the same page:
> trace("hi", "all");
> used to say:
> SwiftScript trace: hi, all
> now says:
> SwiftScript trace: ?:string = hi - Closed, ?:string = all - Closed
> On Wed, 25 May 2011, Mihael Hategan wrote:
> > On Wed, 2011-05-25 at 13:20 -0500, Justin M Wozniak wrote:
> >> This also affects the behavior of trace().
> > Yes. That was the intent. Removing the noise from swiftData.toString().
> >>   Might it impact other Swift
> >> functionality like mappers?
> > I don't think so, but if you can think of a specific scenario, I'm
> > listening.
> >> On Tue, 17 May 2011, Mihael Hategan wrote:
> >>> Indeed. I committed a fix to unwrap swift data when passing values to
> >>> execute() (stdin, out, err, and the arguments in particular).
> >>> I don't think toString() should be "overloaded" like it was.
> >>> On Tue, 2011-05-17 at 16:56 -0500, Justin M Wozniak wrote:
> >>>> I think this change affects arguments to apps:
> >>>> type file;
> >>>> (file f) echo (int i) {
> >>>> app { echo i stdout=@f; }
> >>>> int greetings = 2;
> >>>> file hw = echo(greetings);
> >>>> DEBUG vdl:execute2 JOB_START jobid=echo-tnyfi9ak tr=echo
> >>>> arguments=[greetings:int = 2.0 - Closed]
> >>>> On Fri, 13 May 2011, Mihael Hategan wrote:
> >>>>> I changed that in trunk. It used to be:
> >>>>> org.griphyn.vdl.mapping.RootDataNode identifier
> >>>>> dataset:20110512-2343-5rl3b7x5:720000000072 type Sgt with no value at
> >>>>> dataset=sgt_var (not closed)
> >>>>> That was annoying, noisy, and I had no idea what's what.
> >>>>> It is now:
> >>>>> name:type = value - [Open/Closed]
> >>>>> The provenance data should still be the same, but it may not. So please
> >>>>> let me know if anything breaks.
> >>>>> _______________________________________________
> >>>>> Swift-devel mailing list
> >>>>> Swift-devel at ci.uchicago.edu
> >>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
