[Swift-devel] DataNode.toString()
    Justin M Wozniak
    wozniak at mcs.anl.gov
    Wed May 25 14:53:15 CDT 2011
Ok, just so we're all on the same page:
trace("hi", "all");
used to say:
SwiftScript trace: hi, all
now says:
SwiftScript trace: ?:string = hi - Closed, ?:string = all - Closed
On Wed, 25 May 2011, Mihael Hategan wrote:
> On Wed, 2011-05-25 at 13:20 -0500, Justin M Wozniak wrote:
>> This also affects the behavior of trace().
> Yes. That was the intent. Removing the noise from swiftData.toString().
>>   Might it impact other Swift
>> functionality like mappers?
> I don't think so, but if you can think of a specific scenario, I'm
> listening.
>> On Tue, 17 May 2011, Mihael Hategan wrote:
>>> Indeed. I committed a fix to unwrap swift data when passing values to
>>> execute() (stdin, out, err, and the arguments in particular).
>>> I don't think toString() should be "overloaded" like it was.
>>> On Tue, 2011-05-17 at 16:56 -0500, Justin M Wozniak wrote:
>>>> I think this change affects arguments to apps:
>>>> type file;
>>>> (file f) echo (int i) {
>>>> app { echo i stdout=@f; }
>>>> int greetings = 2;
>>>> file hw = echo(greetings);
>>>> DEBUG vdl:execute2 JOB_START jobid=echo-tnyfi9ak tr=echo
>>>> arguments=[greetings:int = 2.0 - Closed]
>>>> On Fri, 13 May 2011, Mihael Hategan wrote:
>>>>> I changed that in trunk. It used to be:
>>>>> org.griphyn.vdl.mapping.RootDataNode identifier
>>>>> dataset:20110512-2343-5rl3b7x5:720000000072 type Sgt with no value at
>>>>> dataset=sgt_var (not closed)
>>>>> That was annoying, noisy, and I had no idea what's what.
>>>>> It is now:
>>>>> name:type = value - [Open/Closed]
>>>>> The provenance data should still be the same, but it may not. So please
>>>>> let me know if anything breaks.
>>>>> _______________________________________________
>>>>> Swift-devel mailing list
>>>>> Swift-devel at ci.uchicago.edu
>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Justin M Wozniak
