[Swift-devel] DataNode.toString()
Mihael Hategan
hategan at mcs.anl.gov
Wed May 25 14:26:18 CDT 2011
On Wed, 2011-05-25 at 13:20 -0500, Justin M Wozniak wrote:
> This also affects the behavior of trace().
Yes. That was the intent. Removing the noise from swiftData.toString().
> Might it impact other Swift
> functionality like mappers?
I don't think so, but if you can think of a specific scenario, I'm
listening.
> On Tue, 17 May 2011, Mihael Hategan wrote:
> > Indeed. I committed a fix to unwrap swift data when passing values to
> > execute() (stdin, out, err, and the arguments in particular).
> > I don't think toString() should be "overloaded" like it was.
> > On Tue, 2011-05-17 at 16:56 -0500, Justin M Wozniak wrote:
> >> I think this change affects arguments to apps:
> >> type file;
> >> (file f) echo (int i) {
> >> app { echo i stdout=@f; }
> >> int greetings = 2;
> >> file hw = echo(greetings);
> >> DEBUG vdl:execute2 JOB_START jobid=echo-tnyfi9ak tr=echo
> >> arguments=[greetings:int = 2.0 - Closed]
> >> On Fri, 13 May 2011, Mihael Hategan wrote:
> >>> I changed that in trunk. It used to be:
> >>> org.griphyn.vdl.mapping.RootDataNode identifier
> >>> dataset:20110512-2343-5rl3b7x5:720000000072 type Sgt with no value at
> >>> dataset=sgt_var (not closed)
> >>> That was annoying, noisy, and I had no idea what's what.
> >>> It is now:
> >>> name:type = value - [Open/Closed]
> >>> The provenance data should still be the same, but it may not. So please
> >>> let me know if anything breaks.
> >>> _______________________________________________
> >>> Swift-devel mailing list
> >>> Swift-devel at ci.uchicago.edu
> >>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
