[Swift-devel] recent error on beagle
    Mihael Hategan
    hategan at mcs.anl.gov
    Sun May 22 13:51:39 CDT 2011
The second one looks to me like a coaster problem. Can't say much about
the first issue.
Can you try with plain pbs if you want to test the pbs provider?
Mihael
On Sun, 2011-05-22 at 08:39 -0500, ketan wrote:
> I can confirm that the trunk is not usable for pbs provider. I am using
> trunk for submitting jobs on beagle and I see a few unexpected things:
> 1. The stderr is showing inconsistent messages: The results are getting
> written to the output even though stderr doesn't report any.
> 2. qsub jobs being cancelled inadvertantly: I submitted 40 of them
> yesterday, however, only 2 survived today. The log is here:
> http://www.ci.uchicago.edu/~ketan/files/ftdock-20110521-0337-pokpgg89.log
> In addition, the ssh-pbs provider does not seem to be working for large
> runs (it worked for a small number of test runs): Getting unexpected
> stdouts. Following is the stdout:
> http://www.ci.uchicago.edu/~ketan/files/ssh-pbs.stdout
> Following is the log file for the above run:
> http://www.ci.uchicago.edu/~ketan/files/ftdock-20110521-1750-b0cot9sa.log
> Ketan
> On 5/21/11 5:12 PM, Michael Wilde wrote:
> > ----- Original Message -----
> >> On Sat, 2011-05-21 at 17:06 -0400, Glen Hocky wrote:
> >>> as I mentioned, I've been running with Mike's swift which was
> >>> patched
> >>> for beagle. are all the things that make running on beagle work in
> >>> trunk?
> >> No idea.
> >> Mike?
> > Justin, working with Ketan, just applied changes to trunk which should make it work now on Beagle (or any Cray XT5+ or XE).  This uses a different set of sites.xml tags than the prototype in the current Beagle swift 0.92.1 module. Justin has a note on this at:
> >    https://sites.google.com/site/swiftdevel/sites/pbs/cray
> > It was working before for one-node worker jobs; now it should work for multi-node worker jobs as well.
> > Justin and Ketan should comment on the state of testing and readiness of this trunk feature.  Don't try trunk on Beagle till they give the go-ahead.
> > - Mike
> >>>   If so i'll update to the latest and test. I don't think I'm
> >>> using stable...
> >> Ok
> >> Mihael
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
