[Swift-devel] recent error on beagle
    ketan
    ketancmaheshwari at gmail.com
    Sun May 22 08:39:15 CDT 2011
I can confirm that the trunk is not usable for pbs provider. I am using
trunk for submitting jobs on beagle and I see a few unexpected things:
1. The stderr is showing inconsistent messages: The results are getting
written to the output even though stderr doesn't report any.
2. qsub jobs being cancelled inadvertantly: I submitted 40 of them
yesterday, however, only 2 survived today. The log is here:
http://www.ci.uchicago.edu/~ketan/files/ftdock-20110521-0337-pokpgg89.log
In addition, the ssh-pbs provider does not seem to be working for large
runs (it worked for a small number of test runs): Getting unexpected
stdouts. Following is the stdout:
http://www.ci.uchicago.edu/~ketan/files/ssh-pbs.stdout
Following is the log file for the above run:
http://www.ci.uchicago.edu/~ketan/files/ftdock-20110521-1750-b0cot9sa.log
Ketan
On 5/21/11 5:12 PM, Michael Wilde wrote:
>> On Sat, 2011-05-21 at 17:06 -0400, Glen Hocky wrote:
>>> as I mentioned, I've been running with Mike's swift which was
>>> patched
>>> for beagle. are all the things that make running on beagle work in
>>> trunk?
>> No idea.
>> Mike?
> Justin, working with Ketan, just applied changes to trunk which should make it work now on Beagle (or any Cray XT5+ or XE).  This uses a different set of sites.xml tags than the prototype in the current Beagle swift 0.92.1 module. Justin has a note on this at:
>    https://sites.google.com/site/swiftdevel/sites/pbs/cray
> It was working before for one-node worker jobs; now it should work for multi-node worker jobs as well.
> Justin and Ketan should comment on the state of testing and readiness of this trunk feature.  Don't try trunk on Beagle till they give the go-ahead.
> - Mike
>>>   If so i'll update to the latest and test. I don't think I'm
>>> using stable...
>> Ok
>> Mihael
