[Swift-devel] Setting up swift dev environment in Eclipse
    Yadu Nand
    yadudoc1729 at gmail.com
    Tue May 17 13:07:58 CDT 2011
Ignoring abstraction-provider-dcache (as in removing it from the list
of imported
modules ) brought me back to an error saying :
Description	Resource	Path	Location	Type
Project 'abstraction' is missing required Java project:
'abstraction-provider-dcache'	abstraction		Build path	Build Path
Problem
The project cannot be built until build path errors are
resolved	abstraction		Unknown	Java Problem
On Tue, May 17, 2011 at 10:33 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> Either ignore that or close provider-dcache.
> Mihael
> On Tue, 2011-05-17 at 21:44 +0530, Yadu Nand wrote:
>> Hi,
>> I imported the following modules into a new workspace :
>> abstraction
>> abstraction-common
>> abstraction-provider-(coaster,condor,dcache,gt2,gt4_0_0,local,
>>                                      localscheduler, webdav, ssh)
>> grapheditor
>> jglobus
>> karajan
>> resources
>> swift
>> util
>> Now, I am able to compile properly into a java application but 3 errors
>> and 3801 warnings remain. I am not sure if these need to be fixed.
>> So, I'm pasting the 3 errors.
>> org.globus.cog.abstraction.impl.file.local cannot be resolved to a
>> type  FileResourceImpl.java   /abstraction-provider-dcache/src/org/globus/cog/abstraction/impl/file/dcache    line
>> 20    Java Problem
>> The method resolve(String) is undefined for the type
>> FileResourceImpl      FileResourceImpl.java   /abstraction-provider-dcache/src/org/globus/cog/abstraction/impl/file/dcache    line
>> 78    Java Problem
>> 79    Java Problem
>> On Sun, May 15, 2011 at 4:03 AM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
>> > On Sun, 2011-05-15 at 03:54 +0530, Yadu Nand wrote:
>> >> Sorry missed the link to the doc I was referring to.
>> >> Here it is
>> >> https://sites.google.com/site/swiftdevel/internals/new-developer-guide
>> > That document doesn't seem quite complete.
>> > I personally use eclipse to compile and run swift.
>> > Essentially things are organized into modules (in the checkout they
>> > would be in cog/modules). All these modules should have eclipse projects
>> > inside them (i.e. cog/modules/swift/.project). These modules may depend
>> > on one another. You should import them one by one ending up with
>> > multiple eclipse projects.
>> > The essential modules are:
>> > swift
>> > abstraction
>> > abstraction-common
>> > provider-(local, gt2, coaster)
>> > jglobus
>> > util
>> > karajan
>> > There may be some others. In that case, eclipse will complain about
>> > missing projects, so also add the missing projects/modules if necessary.
Thanks and Regards,
Yadu Nand B
