[Swift-devel] Setting up swift dev environment in Eclipse
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue May 17 12:03:30 CDT 2011
Either ignore that or close provider-dcache.
Mihael
On Tue, 2011-05-17 at 21:44 +0530, Yadu Nand wrote:
> Hi,
> I imported the following modules into a new workspace :
> abstraction
> abstraction-common
> abstraction-provider-(coaster,condor,dcache,gt2,gt4_0_0,local,
>                                      localscheduler, webdav, ssh)
> grapheditor
> jglobus
> karajan
> resources
> swift
> util
> Now, I am able to compile properly into a java application but 3 errors
> and 3801 warnings remain. I am not sure if these need to be fixed.
> So, I'm pasting the 3 errors.
> Description	Resource	Path	Location	Type
> org.globus.cog.abstraction.impl.file.local cannot be resolved to a
> type	FileResourceImpl.java	/abstraction-provider-dcache/src/org/globus/cog/abstraction/impl/file/dcache	line
> 20	Java Problem
> The method resolve(String) is undefined for the type
> FileResourceImpl	FileResourceImpl.java	/abstraction-provider-dcache/src/org/globus/cog/abstraction/impl/file/dcache	line
> 78	Java Problem
> 79	Java Problem
> On Sun, May 15, 2011 at 4:03 AM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> > On Sun, 2011-05-15 at 03:54 +0530, Yadu Nand wrote:
> >> Sorry missed the link to the doc I was referring to.
> >> Here it is
> >> https://sites.google.com/site/swiftdevel/internals/new-developer-guide
> > That document doesn't seem quite complete.
> > I personally use eclipse to compile and run swift.
> > Essentially things are organized into modules (in the checkout they
> > would be in cog/modules). All these modules should have eclipse projects
> > inside them (i.e. cog/modules/swift/.project). These modules may depend
> > on one another. You should import them one by one ending up with
> > multiple eclipse projects.
> > The essential modules are:
> > swift
> > abstraction
> > abstraction-common
> > provider-(local, gt2, coaster)
> > jglobus
> > util
> > karajan
> > There may be some others. In that case, eclipse will complain about
> > missing projects, so also add the missing projects/modules if necessary.
