[Swift-devel] cog 4.1.8 + release-0.92 branch build failure
    Justin M Wozniak
    wozniak at mcs.anl.gov
    Sat Mar 26 10:47:04 CDT 2011
Sorry about that- there was a minor merge error.  Please update cog and
try again.
 	Thanks for the report
 	Justin
On Fri, 25 Mar 2011, Allan Espinosa wrote:
> delete.jar:
>     [echo] [karajan]: DELETE.JAR (cog-karajan-0.36-dev.jar)
> compile:
>     [echo] [karajan]: COMPILE
>    [mkdir] Created dir:
> /autonfs/home/aespinosa/swift/cogkit/modules/karajan/build
>    [javac] Compiling 493 source files to
>    [javac] /autonfs/home/aespinosa/swift/cogkit/modules/karajan/src/org/globus/cog/karajan/workflow/nodes/grid/AbstractGridNode.java:189:
> setStack(org.globus.cog.abstraction.interfaces.Task,org.globus.cog.karajan.stack.VariableStack)
> is already defined in
> org.globus.cog.karajan.workflow.nodes.grid.AbstractGridNode
>    [javac]     protected final void setStack(Task task, VariableStack stack) {
>    [javac]                          ^
>    [javac] Note: Some input files use or override a deprecated API.
>    [javac] Note: Recompile with -Xlint:deprecation for details.
>    [javac] Note: Some input files use unchecked or unsafe operations.
>    [javac] Note: Recompile with -Xlint:unchecked for details.
>    [javac] 1 error
Justin M Wozniak
