[Swift-devel] cog 4.1.8 + release-0.92 branch build failure
    Allan Espinosa
    aespinosa at cs.uchicago.edu
    Mon Mar 28 11:34:00 CDT 2011
The build now works for me.
-Allan
2011/3/26 Justin M Wozniak <wozniak at mcs.anl.gov>:
> Sorry about that- there was a minor merge error.  Please update cog and try
> again.
>        Thanks for the report
>        Justin
> On Fri, 25 Mar 2011, Allan Espinosa wrote:
>> delete.jar:
>>    [echo] [karajan]: DELETE.JAR (cog-karajan-0.36-dev.jar)
>> compile:
>>    [echo] [karajan]: COMPILE
>>   [mkdir] Created dir:
>> /autonfs/home/aespinosa/swift/cogkit/modules/karajan/build
>>   [javac] Compiling 493 source files to
>>   [javac]
>> /autonfs/home/aespinosa/swift/cogkit/modules/karajan/src/org/globus/cog/karajan/workflow/nodes/grid/AbstractGridNode.java:189:
>> setStack(org.globus.cog.abstraction.interfaces.Task,org.globus.cog.karajan.stack.VariableStack)
>> is already defined in
>> org.globus.cog.karajan.workflow.nodes.grid.AbstractGridNode
>>   [javac]     protected final void setStack(Task task, VariableStack
>> stack) {
>>   [javac]                          ^
>>   [javac] Note: Some input files use or override a deprecated API.
>>   [javac] Note: Recompile with -Xlint:deprecation for details.
>>   [javac] Note: Some input files use unchecked or unsafe operations.
>>   [javac] Note: Recompile with -Xlint:unchecked for details.
>>   [javac] 1 error
> Justin M Wozniak
