[Swift-devel] cog 4.1.8 + release-0.92 branch build failure
    Allan Espinosa
    aespinosa at cs.uchicago.edu
    Fri Mar 25 18:49:08 CDT 2011
delete.jar:
     [echo] [karajan]: DELETE.JAR (cog-karajan-0.36-dev.jar)
compile:
     [echo] [karajan]: COMPILE
    [mkdir] Created dir:
/autonfs/home/aespinosa/swift/cogkit/modules/karajan/build
    [javac] Compiling 493 source files to
    [javac] /autonfs/home/aespinosa/swift/cogkit/modules/karajan/src/org/globus/cog/karajan/workflow/nodes/grid/AbstractGridNode.java:189:
setStack(org.globus.cog.abstraction.interfaces.Task,org.globus.cog.karajan.stack.VariableStack)
is already defined in
org.globus.cog.karajan.workflow.nodes.grid.AbstractGridNode
    [javac]     protected final void setStack(Task task, VariableStack stack) {
    [javac]                          ^
    [javac] Note: Some input files use or override a deprecated API.
    [javac] Note: Recompile with -Xlint:deprecation for details.
    [javac] Note: Some input files use unchecked or unsafe operations.
    [javac] Note: Recompile with -Xlint:unchecked for details.
    [javac] 1 error
-Allan
