[Swift-devel] "Timer was cancelled" error on Beagle on Swift	script termination
    Mihael Hategan
    hategan at mcs.anl.gov
    Sat Mar 26 04:26:00 CDT 2011
I will look at it on Sunday or Monday.
Mihael
On Sat, 2011-03-26 at 00:28 -0500, Ketan Maheshwari wrote:
> Hi,
> The timer error: "Timer was cancelled" persists on beagle. Does
> anybody been able to resolve it so far?
> The stack I got today is quite similar to the previous ones:
> Got exception in send
> java.lang.IllegalStateException: Timer was cancelled
>     at java.util.Timer.scheduleImpl(Timer.java:564)
>     at java.util.Timer.schedule(Timer.java:449)
>     at
> org.globus.cog.karajan.workflow.service.commands.Command.setupReplyTimeoutChecker(Command.java:155)
>     at
> org.globus.cog.karajan.workflow.service.commands.Command.dataSent(Command.java:149)
>     at
> org.globus.cog.karajan.workflow.service.channels.AbstractPipedChannel.actualSend(AbstractPipedChannel.java:89)
>     at
> $Sender.run(AbstractPipedChannel.java:115)
>     at
>     at
>     at
>     at
>     at
>     at
>     at
> org.globus.cog.karajan.workflow.service.channels.AbstractStreamKarajanChannel$Sender.run(AbstractStreamKarajanChannel.java:253)
> Canceling job 21995.sdb
> Ketan
> On Mon, Mar 21, 2011 at 6:33 PM, Mihael Hategan <hategan at mcs.anl.gov>
> wrote:
>         So it is related to PBS. Please send me logs with this
>         problem. The
>         timer thing shouldn't be happening.
>         On Mon, 2011-03-21 at 17:30 -0400, Glen Hocky wrote:
>         > I got rid of the problem by setting my project as per Ti's
>         > instructions
>         > projects --available
>         > projects --set PROJECT
>         > On Mon, Mar 21, 2011 at 4:44 PM, Mihael Hategan
>         > wrote:
>         >         On Mon, 2011-03-21 at 13:23 -0500, Michael Wilde
>         wrote:
>         >         > Mihael, all, do you have any thoughts on what that
>         might be?
>         >         Yes, but what I think it is wouldn't (in any obvious
>         way I can
>         >         see) be
>         >         influenced by changes in the environment.
>         >         If you look at the logs, is there anything else
>         suspicious
>         >         going on?
>         >         Mihael
>         >         _______________________________________________
>         >         Swift-devel mailing list
>         >         Swift-devel at ci.uchicago.edu
>         http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
