[Swift-devel] "Timer was cancelled" error on Beagle on Swift script termination
Ketan Maheshwari ketancmaheshwari at gmail.com
Sat Mar 26 00:28:04 CDT 2011
The timer error: "Timer was cancelled" persists on beagle. Does anybody been
able to resolve it so far?
The stack I got today is quite similar to the previous ones:
Got exception in send
java.lang.IllegalStateException: Timer was cancelled
    at java.util.Timer.scheduleImpl(Timer.java:564)
    at java.util.Timer.schedule(Timer.java:449)
    at
org.globus.cog.karajan.workflow.service.commands.Command.setupReplyTimeoutChecker(Command.java:155)
    at
org.globus.cog.karajan.workflow.service.commands.Command.dataSent(Command.java:149)
    at
org.globus.cog.karajan.workflow.service.channels.AbstractPipedChannel.actualSend(AbstractPipedChannel.java:89)
    at
org.globus.cog.karajan.workflow.service.channels.AbstractPipedChannel$Sender.run(AbstractPipedChannel.java:115)
    at
    at
    at
    at
    at
    at
    at
org.globus.cog.karajan.workflow.service.channels.AbstractStreamKarajanChannel$Sender.run(AbstractStreamKarajanChannel.java:253)
Canceling job 21995.sdb
Ketan
On Mon, Mar 21, 2011 at 6:33 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> So it is related to PBS. Please send me logs with this problem. The
> timer thing shouldn't be happening.
> On Mon, 2011-03-21 at 17:30 -0400, Glen Hocky wrote:
> > I got rid of the problem by setting my project as per Ti's
> > instructions
> > projects --available
> > projects --set PROJECT
> > On Mon, Mar 21, 2011 at 4:44 PM, Mihael Hategan <hategan at mcs.anl.gov>
> > wrote:
> >         On Mon, 2011-03-21 at 13:23 -0500, Michael Wilde wrote:
> >         > Mihael, all, do you have any thoughts on what that might be?
> >         Yes, but what I think it is wouldn't (in any obvious way I can
> >         see) be
> >         influenced by changes in the environment.
> >         If you look at the logs, is there anything else suspicious
> >         going on?
> >         Mihael
> >         _______________________________________________
> >         Swift-devel mailing list
> >         Swift-devel at ci.uchicago.edu
> >         http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110326/69434d5d/attachment.html>
