[Swift-devel] "Timer was cancelled" error on Beagle on Swift	script termination
    Mihael Hategan
    hategan at mcs.anl.gov
    Sun Mar 27 15:40:05 CDT 2011
Ok. I need logs. Logs please. Logs!!!
On Sat, 2011-03-26 at 02:26 -0700, Mihael Hategan wrote:
> I will look at it on Sunday or Monday.
> Mihael
> On Sat, 2011-03-26 at 00:28 -0500, Ketan Maheshwari wrote:
> > Hi,
> > The timer error: "Timer was cancelled" persists on beagle. Does
> > anybody been able to resolve it so far?
> > The stack I got today is quite similar to the previous ones:
> > Got exception in send
> > java.lang.IllegalStateException: Timer was cancelled
> >     at java.util.Timer.scheduleImpl(Timer.java:564)
> >     at java.util.Timer.schedule(Timer.java:449)
> >     at
> > org.globus.cog.karajan.workflow.service.commands.Command.setupReplyTimeoutChecker(Command.java:155)
> >     at
> > org.globus.cog.karajan.workflow.service.commands.Command.dataSent(Command.java:149)
> >     at
> > org.globus.cog.karajan.workflow.service.channels.AbstractPipedChannel.actualSend(AbstractPipedChannel.java:89)
> >     at
> > $Sender.run(AbstractPipedChannel.java:115)
> >     at
> >     at
> >     at
> >     at
> >     at
> >     at
> >     at
> > org.globus.cog.karajan.workflow.service.channels.AbstractStreamKarajanChannel$Sender.run(AbstractStreamKarajanChannel.java:253)
> > Canceling job 21995.sdb
> > Ketan
> > On Mon, Mar 21, 2011 at 6:33 PM, Mihael Hategan <hategan at mcs.anl.gov>
> > wrote:
> >         So it is related to PBS. Please send me logs with this
> >         problem. The
> >         timer thing shouldn't be happening.
> >         On Mon, 2011-03-21 at 17:30 -0400, Glen Hocky wrote:
> >         > I got rid of the problem by setting my project as per Ti's
> >         > instructions
> >         > projects --available
> >         > projects --set PROJECT
> >         > On Mon, Mar 21, 2011 at 4:44 PM, Mihael Hategan
> >         > wrote:
> >         >         On Mon, 2011-03-21 at 13:23 -0500, Michael Wilde
> >         wrote:
> >         >         > Mihael, all, do you have any thoughts on what that
> >         might be?
> >         >         Yes, but what I think it is wouldn't (in any obvious
> >         way I can
> >         >         see) be
> >         >         influenced by changes in the environment.
> >         >         If you look at the logs, is there anything else
> >         suspicious
> >         >         going on?
> >         >         Mihael
> >         >         _______________________________________________
> >         >         Swift-devel mailing list
> >         >         Swift-devel at ci.uchicago.edu
> >         http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
