[Swift-devel] latest trunk
    Sarah Kenny
    skenny at uchicago.edu
    Mon Mar 21 17:29:53 CDT 2011
it works fine under .92 and is something i often use for testing, but no
worries i can debug more, i just thought maybe there was a recent commit
that would jump out at someone as the potential cause of this behavior.
~sk
On Mon, Mar 21, 2011 at 3:27 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> Sarah,
> I wont be able to test and help debug this today, but I notice that your
> app function declares but does not set the file return value "min".  Was (or
> is) the exact same script working under 0.92 in this manner?
> If you think this should work under trunk, I would first package up a
> version that anyone can run (ie include a mock RInvoke script, tc, sites,
> and properties file.
> The try to create a trunk version as of about a week or 2 ago, and see if
> you find find the trunk rev that broke it.
> If you can reproduce the error on latest trunk, posting the log and all the
> specs/files needed to run it would help Justin or Mihael try to find the
> problem.
> But first make sure the script is logically correct w.r.t the min return
> value. Looks wrong to me, but I may be missing something obvious.
> - Mike
> type file;
> type Rscript;
> type mxModel;
> app (mxModel min) mxModelProcessor(file covMatrix, Rscript mxModProc, int
> modnum, float weight, string cond)
>         RInvoke @filename(mxModProc) @filename(covMatrix) modnum weight
> cond;
> file covMatrix<single_file_mapper;file="./gestspeech.cov">;
> Rscript mxScript<single_file_mapper;file=@strcat("scripts/stest.R")>;
> int totalperms[] = [1:10];
> float initweight = .5;
> foreach perm in totalperms{
> mxModel modmin<single_file_mapper;
> file=@strcat("./results/speech_",perm,".rdata")>;
>         modmin = mxModelProcessor(covMatrix, mxScript, perm, initweight,
> "speech");
> the R script it calls is actually just a sleep job
> On Mon, Mar 21, 2011 at 2:57 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
>> Can you post the script?
>> hmmm....so i just (a moment ago) built from trunk and on a quick test run
>> (defaulting to localhost) i seem to be getting an infinite stream of
>> something like this:
>> No events in 10s.
>> Badness
>> Registered futures:
>> int[] totalperms  Closed, 10 elements, 0 listeners
>> Waiting threads:
>> 0-4
>> No events in 10s.
>> Badness
>> Registered futures:
>> Waiting threads:
>> 0-4
>> it's a simple test script that runs fine in .92, anyone else experiencing
>> this?
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
>> Michael Wilde
>> Computation Institute, University of Chicago
>> Mathematics and Computer Science Division
>> Argonne National Laboratory
> Michael Wilde
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110321/b7fe23c6/attachment.html>
