[Swift-devel] latest trunk
    Michael Wilde
    wilde at mcs.anl.gov
    Mon Mar 21 17:27:21 CDT 2011
Sarah,
I wont be able to test and help debug this today, but I notice that your app function declares but does not set the file return value "min". Was (or is) the exact same script working under 0.92 in this manner?
If you think this should work under trunk, I would first package up a version that anyone can run (ie include a mock RInvoke script, tc, sites, and properties file.
The try to create a trunk version as of about a week or 2 ago, and see if you find find the trunk rev that broke it.
If you can reproduce the error on latest trunk, posting the log and all the specs/files needed to run it would help Justin or Mihael try to find the problem.
But first make sure the script is logically correct w.r.t the min return value. Looks wrong to me, but I may be missing something obvious.
- Mike
----- Original Message -----
type file;
type Rscript;
type mxModel;
app (mxModel min) mxModelProcessor(file covMatrix, Rscript mxModProc, int modnum, float weight, string cond)
RInvoke @filename(mxModProc) @filename(covMatrix) modnum weight cond;
file covMatrix<single_file_mapper;file="./gestspeech.cov">;
Rscript mxScript<single_file_mapper;file=@strcat("scripts/stest.R")>;
int totalperms[] = [1:10];
float initweight = .5;
foreach perm in totalperms{
mxModel modmin<single_file_mapper; file=@strcat("./results/speech_",perm,".rdata")>;
modmin = mxModelProcessor(covMatrix, mxScript, perm, initweight, "speech");
the R script it calls is actually just a sleep job
On Mon, Mar 21, 2011 at 2:57 PM, Michael Wilde < wilde at mcs.anl.gov > wrote:
Can you post the script?
hmmm....so i just (a moment ago) built from trunk and on a quick test run (defaulting to localhost) i seem to be getting an infinite stream of something like this:
No events in 10s.
Badness
Registered futures:
int[] totalperms Closed, 10 elements, 0 listeners
Waiting threads:
0-4
No events in 10s.
Badness
Registered futures:
Waiting threads:
0-4
it's a simple test script that runs fine in .92, anyone else experiencing this?
Swift-devel mailing list
Swift-devel at ci.uchicago.edu
http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
Michael Wilde
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110321/de5db20b/attachment.html>
