[Swift-devel] latest trunk
    Sarah Kenny
    skenny at uchicago.edu
    Mon Mar 21 17:37:11 CDT 2011
oh, problem was bad tc file...now i have to figure out why swift decided not
to tell me that :P
On Mon, Mar 21, 2011 at 3:29 PM, Sarah Kenny <skenny at uchicago.edu> wrote:
> it works fine under .92 and is something i often use for testing, but no
> worries i can debug more, i just thought maybe there was a recent commit
> that would jump out at someone as the potential cause of this behavior.
> ~sk
> On Mon, Mar 21, 2011 at 3:27 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
>> Sarah,
>> I wont be able to test and help debug this today, but I notice that your
>> app function declares but does not set the file return value "min".  Was (or
>> is) the exact same script working under 0.92 in this manner?
>> If you think this should work under trunk, I would first package up a
>> version that anyone can run (ie include a mock RInvoke script, tc, sites,
>> and properties file.
>> The try to create a trunk version as of about a week or 2 ago, and see if
>> you find find the trunk rev that broke it.
>> If you can reproduce the error on latest trunk, posting the log and all
>> the specs/files needed to run it would help Justin or Mihael try to find the
>> problem.
>> But first make sure the script is logically correct w.r.t the min return
>> value. Looks wrong to me, but I may be missing something obvious.
>> - Mike
>> type file;
>> type Rscript;
>> type mxModel;
>> app (mxModel min) mxModelProcessor(file covMatrix, Rscript mxModProc, int
>> modnum, float weight, string cond)
>>         RInvoke @filename(mxModProc) @filename(covMatrix) modnum weight
>> cond;
>> file covMatrix<single_file_mapper;file="./gestspeech.cov">;
>> Rscript mxScript<single_file_mapper;file=@strcat("scripts/stest.R")>;
>> int totalperms[] = [1:10];
>> float initweight = .5;
>> foreach perm in totalperms{
>> mxModel modmin<single_file_mapper;
>> file=@strcat("./results/speech_",perm,".rdata")>;
>>         modmin = mxModelProcessor(covMatrix, mxScript, perm, initweight,
>> "speech");
>> the R script it calls is actually just a sleep job
>> On Mon, Mar 21, 2011 at 2:57 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
>>> Can you post the script?
>>> hmmm....so i just (a moment ago) built from trunk and on a quick test run
>>> (defaulting to localhost) i seem to be getting an infinite stream of
>>> something like this:
>>> No events in 10s.
>>> Badness
>>> Registered futures:
>>> int[] totalperms  Closed, 10 elements, 0 listeners
>>> Waiting threads:
>>> 0-4
>>> No events in 10s.
>>> Badness
>>> Registered futures:
>>> Waiting threads:
>>> 0-4
>>> it's a simple test script that runs fine in .92, anyone else experiencing
>>> this?
>>> _______________________________________________
>>> Swift-devel mailing list
>>> Swift-devel at ci.uchicago.edu
>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
>>> Michael Wilde
>>> Computation Institute, University of Chicago
>>> Mathematics and Computer Science Division
>>> Argonne National Laboratory
>> Michael Wilde
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110321/0c8860ba/attachment.html>
