[Swift-devel] "Timer was cancelled" error on Beagle on Swift	script termination
    Michael Wilde
    wilde at mcs.anl.gov
    Mon Mar 21 13:23:56 CDT 2011
Ketan, I recall that you ran the same example last week, and did not report this error at that time.
Is your impressions the same as mine: that something changed either in Beagle or in the Swift revision we are using there, to cause this?
Im somewhat suspicious that a recent change in Beagle's PBS behavior is causing this error in Swift.
Mihael, all, do you have any thoughts on what that might be?
- Mike
----- Original Message -----
I tried on my home and am getting the same error stack as well.
[ketan at login2:catsn.works]$ swift -config cf -tc.file tc -sites.file beagle-coaster.xml catsn.swift -n=1
Swift svn swift-r4143 (swift modified locally) cog-r3056 (cog modified locally)
RunID: 20110321-1213-4abfllee
Progress:
Progress: Submitting:1
Progress: Active:1
Final status: Finished successfully:1
Got exception in send
java.lang.IllegalStateException: Timer was cancelled
at java.util.Timer.scheduleImpl(Timer.java:564)
at java.util.Timer.schedule(Timer.java:449)
at org.globus.cog.karajan.workflow.service.commands.Command.setupReplyTimeoutChecker(Command.java:155)
at org.globus.cog.karajan.workflow.service.commands.Command.dataSent(Command.java:149)
at org.globus.cog.karajan.workflow.service.channels.AbstractPipedChannel.actualSend(AbstractPipedChannel.java:89)
at org.globus.cog.karajan.workflow.service.channels.AbstractPipedChannel$Sender.run(AbstractPipedChannel.java:115)
at org.globus.cog.karajan.workflow.service.channels.AbstractStreamKarajanChannel$Sender.run(AbstractStreamKarajanChannel.java:253)
Canceling job 19904.sdb
On Mon, Mar 21, 2011 at 12:14 PM, Michael Wilde < wilde at mcs.anl.gov > wrote:
I had not run Swift on beagle for the past two weeks. When I started again last night, Im now getting some kind of coaster service timeout error when the script terminates. The script seems to run OK up to termination.
The error is:
Canceling job 19876.sdb
Is anyone seeing the same thing? Any idea why?
This is running swift at:
login1$ which swift
/home/wilde/swift/rev/swift-r4143+cog-r3056+pbscoast/bin/swift
login1$ swift -version
The log for this example is on CI net in /home/wilde/swift/lab/catsn-20110320-2257-tpoi32je.log
Run command and output:
login1$ swift -config cf -tc.file tc -sites.file beagle-coaster.xml catsn.swift -n=10
RunID: 20110320-2257-tpoi32je
Progress:
Progress: Submitted:9 Active:1
Trying to release previously released contact: 3
Final status: Finished successfully:10
login1$
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
Swift-devel mailing list
Swift-devel at ci.uchicago.edu
http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Michael Wilde
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110321/e46d8de8/attachment.html>
