[Swift-devel] "Timer was cancelled" error on Beagle on Swift script termination
Justin M Wozniak wozniak at mcs.anl.gov
Mon Mar 21 13:30:49 CDT 2011
PBS is a possibility- did you update from trunk in the last 2 hours?
On Mon, 21 Mar 2011, Michael Wilde wrote:
> Ketan, I recall that you ran the same example last week, and did not
> report this error at that time.
> Is your impressions the same as mine: that something changed either in
> Beagle or in the Swift revision we are using there, to cause this?
> Im somewhat suspicious that a recent change in Beagle's PBS behavior is
> causing this error in Swift.
> Mihael, all, do you have any thoughts on what that might be?
> - Mike
> Hi,
> I tried on my home and am getting the same error stack as well.
> [ketan at login2:catsn.works]$ swift -config cf -tc.file tc -sites.file beagle-coaster.xml catsn.swift -n=1
> Swift svn swift-r4143 (swift modified locally) cog-r3056 (cog modified locally)
> RunID: 20110321-1213-4abfllee
> Progress:
> Progress: Submitting:1
> Progress: Active:1
> Final status: Finished successfully:1
> Got exception in send
> java.lang.IllegalStateException: Timer was cancelled
> at java.util.Timer.scheduleImpl(Timer.java:564)
> at java.util.Timer.schedule(Timer.java:449)
> at org.globus.cog.karajan.workflow.service.commands.Command.setupReplyTimeoutChecker(Command.java:155)
> at org.globus.cog.karajan.workflow.service.commands.Command.dataSent(Command.java:149)
> at org.globus.cog.karajan.workflow.service.channels.AbstractPipedChannel.actualSend(AbstractPipedChannel.java:89)
> at org.globus.cog.karajan.workflow.service.channels.AbstractPipedChannel$Sender.run(AbstractPipedChannel.java:115)
> at org.globus.cog.karajan.workflow.service.channels.AbstractStreamKarajanChannel$Sender.run(AbstractStreamKarajanChannel.java:253)
> Canceling job 19904.sdb
> On Mon, Mar 21, 2011 at 12:14 PM, Michael Wilde < wilde at mcs.anl.gov > wrote:
> I had not run Swift on beagle for the past two weeks. When I started again last night, Im now getting some kind of coaster service timeout error when the script terminates. The script seems to run OK up to termination.
> The error is:
> Canceling job 19876.sdb
> Is anyone seeing the same thing? Any idea why?
> This is running swift at:
> login1$ which swift
> /home/wilde/swift/rev/swift-r4143+cog-r3056+pbscoast/bin/swift
> login1$ swift -version
> The log for this example is on CI net in /home/wilde/swift/lab/catsn-20110320-2257-tpoi32je.log
> Run command and output:
> login1$ swift -config cf -tc.file tc -sites.file beagle-coaster.xml catsn.swift -n=10
> RunID: 20110320-2257-tpoi32je
> Progress:
> Progress: Submitted:9 Active:1
> Trying to release previously released contact: 3
> Final status: Finished successfully:10
> login1$
Justin M Wozniak
