[Swift-devel] "Timer was cancelled" error on Beagle on Swift	script termination
    Ketan Maheshwari
    ketancmaheshwari at gmail.com
    Mon Mar 21 13:16:34 CDT 2011
I tried on my home and am getting the same error stack as well.
[ketan at login2:catsn.works]$ swift -config cf -tc.file tc -sites.file
beagle-coaster.xml catsn.swift -n=1
Swift svn swift-r4143 (swift modified locally) cog-r3056 (cog modified
locally)
RunID: 20110321-1213-4abfllee
Progress:
Progress:  Submitting:1
Progress:  Active:1
Final status:  Finished successfully:1
Got exception in send
java.lang.IllegalStateException: Timer was cancelled
    at java.util.Timer.scheduleImpl(Timer.java:564)
    at java.util.Timer.schedule(Timer.java:449)
    at
org.globus.cog.karajan.workflow.service.commands.Command.setupReplyTimeoutChecker(Command.java:155)
    at
org.globus.cog.karajan.workflow.service.commands.Command.dataSent(Command.java:149)
    at
org.globus.cog.karajan.workflow.service.channels.AbstractPipedChannel.actualSend(AbstractPipedChannel.java:89)
    at
org.globus.cog.karajan.workflow.service.channels.AbstractPipedChannel$Sender.run(AbstractPipedChannel.java:115)
    at
    at
    at
    at
    at
    at
    at
org.globus.cog.karajan.workflow.service.channels.AbstractStreamKarajanChannel$Sender.run(AbstractStreamKarajanChannel.java:253)
Canceling job 19904.sdb
    at
    at
    at
On Mon, Mar 21, 2011 at 12:14 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> I had not run Swift on beagle for the past two weeks. When I started again
> last night, Im now getting some kind of coaster service timeout error when
> the script terminates. The script seems to run OK up to termination.
> The error is:
> Canceling job 19876.sdb
> Is anyone seeing the same thing? Any idea why?
> This is running swift at:
> login1$ which swift
> /home/wilde/swift/rev/swift-r4143+cog-r3056+pbscoast/bin/swift
> login1$ swift -version
> locally)
> The log for this example is on CI net in
> /home/wilde/swift/lab/catsn-20110320-2257-tpoi32je.log
> Run command and output:
> login1$ swift -config cf -tc.file tc -sites.file beagle-coaster.xml
> catsn.swift -n=10
> locally)
> RunID: 20110320-2257-tpoi32je
> Progress:
> Progress:  Submitted:9  Active:1
> Trying to release previously released contact: 3
> Final status:  Finished successfully:10
>        at
>        at
>        at
>        at
>        at
>        at
>        at
>        at
> login1$
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110321/4ec37105/attachment.html>
