[Swift-devel] "Timer was cancelled" error on Beagle on Swift script	termination
    Michael Wilde
    wilde at mcs.anl.gov
    Mon Mar 21 12:14:44 CDT 2011
I had not run Swift on beagle for the past two weeks. When I started again last night, Im now getting some kind of coaster service timeout error when the script terminates. The script seems to run OK up to termination.
The error is:
Canceling job 19876.sdb
Got exception in send
java.lang.IllegalStateException: Timer was cancelled
Is anyone seeing the same thing? Any idea why?
This is running swift at:
login1$ which swift
/home/wilde/swift/rev/swift-r4143+cog-r3056+pbscoast/bin/swift
login1$ swift -version
Swift svn swift-r4143 (swift modified locally) cog-r3056 (cog modified locally)
The log for this example is on CI net in /home/wilde/swift/lab/catsn-20110320-2257-tpoi32je.log
Run command and output:
login1$ swift -config cf -tc.file tc -sites.file beagle-coaster.xml catsn.swift -n=10
RunID: 20110320-2257-tpoi32je
Progress:
Progress:  Submitted:9  Active:1
Trying to release previously released contact: 3
Final status:  Finished successfully:10
	at java.util.Timer.scheduleImpl(Timer.java:564)
	at java.util.Timer.schedule(Timer.java:449)
	at org.globus.cog.karajan.workflow.service.commands.Command.setupReplyTimeoutChecker(Command.java:155)
	at org.globus.cog.karajan.workflow.service.commands.Command.dataSent(Command.java:149)
	at org.globus.cog.karajan.workflow.service.channels.AbstractPipedChannel.actualSend(AbstractPipedChannel.java:89)
	at org.globus.cog.karajan.workflow.service.channels.AbstractPipedChannel$Sender.run(AbstractPipedChannel.java:115)
login1$
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
