[Swift-devel] swift on ranger
Ketan Maheshwari
ketancmaheshwari at gmail.com
Thu Jun 30 21:49:48 CDT 2011
On Thu, Jun 30, 2011 at 9:33 PM, Sarah Kenny <skenny at uchicago.edu> wrote:
> i'm able to get jobs into the queue with this sites file:
> config>
> <import file="sys.xml"/>
> <import file="vdl-lib.xml"/>
> <set name="username">
> <arg><vdl:new type="string" value="user"/></arg>
> </set>
> <!-- RANGER @ tg-login.ranger.tacc.teragrid.org -->
> <pool handle="RANGER">
> <profile namespace="karajan" key="initialScore">1</profile>
> <profile namespace="karajan" key="jobThrottle">10</profile>
> <profile namespace="globus" key="project">TG-DBS080004N</profile>
> <profile namespace="globus" key="maxwalltime">240</profile>
> <profile namespace="globus" key="queue">normal</profile>
> <filesystem provider="gsiftp" url="gsiftp://
> gridftp.ranger.tacc.teragrid.org"/>
> <execution provider="gt2" jobmanager="SGE" url="
> gatekeeper.ranger.tacc.teragrid.org"/>
> <workdirectory>/work/00043/tg457040/sidgrid_out/{username}</workdirectory>
> </pool>
> </config>
> using gt2 for the exec provider...but yeah, can't get in the queue with
> coasters
The above works for me too.
> On Thu, Jun 30, 2011 at 6:37 PM, Ketan Maheshwari <
> ketancmaheshwari at gmail.com> wrote:
>> I tried provider=gt2 and gt4 but get following:
>> case: provider=gt2, jobManager="gt2:fork"
>> RunID: 20110630-2018-sjjtfjs8
>> Progress:
>> Progress: Stage in:1
>> Invalid GSSCredentials
>> Caused by:
>> org.globus.cog.abstraction.impl.common.task.InvalidSecurityContextException:
>> Caused by: GSSException: Invalid name provided [Caused by: [JGLOBUS-112]
>> Malformed name, "=" missing in "fork"]
>> Failed to transfer wrapper log from catsn-20110630-2018-sjjtfjs8/info/c on
>> RANGER
>> Caused by:
>> Failed to transfer wrapper log from catsn-20110630-2018-sjjtfjs8/info/e on
>> RANGER
>> Progress: Failed:1
>> Exception in cat:
>> Arguments: [data.txt]
>> Host: RANGER
>> Directory: catsn-20110630-2018-sjjtfjs8/jobs/e/cat-e1g55cck
>> stderr.txt:
>> stdout.txt:
>> log is at :
>> /home/ketan/osg-tg-effort/ranger-catsn/catsn-20110630-2033-l3zo296g.log
>> no gram log was created.
>> case: provider=gt4, jobManager="gt2:fork"
>> RunID: 20110630-2019-tn0n27kb
>> Progress:
>> Progress: Submitted:1
>> Cannot submit job: The AXIS engine could not find a target service to
>> invoke! targetService is ManagedJobFactoryService
>> Caused by:
>> org.globus.cog.abstraction.impl.common.task.TaskSubmissionException: Cannot
>> submit job: The AXIS engine could not find a target service to invoke!
>> Caused by: The AXIS engine could not find a target service to invoke!
>> Failed to transfer wrapper log from catsn-20110630-2019-tn0n27kb/info/5 on
>> RANGER
>> Caused by:
>> the log is:
>> /home/ketan/osg-tg-effort/ranger-catsn/catsn-20110630-2036-zcqs7td6.log
>> On Thu, Jun 30, 2011 at 8:05 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
>>> Can you send the Ranger-side GRAM log from the run, as well as a pointer
>>> to the log and site file?
>>> I meant, by the way, a non-coaster run with the GT2 provider and
>>> jobmanager SGE.
>>> A Condor-G test to both the fork and SGE jobmanagers would be helpful
>>> too.
>>> - Mike
>>> Mike, All,
>>> gt2:fork works.
>>> gt2:SGE doesn't, I get similar stage-in, submitted, submitted ... as with
>>> gt2:gt2:SGE
>>> On Thu, Jun 30, 2011 at 6:37 PM, Michael Wilde <wilde at mcs.anl.gov>wrote:
>>>> Ketan,
>>>> Can you try a single catsn job with just the GT2 provider, first to the
>>>> Ranger fork job manager and then to the SGE jobmanager?
>>>> - Mike
>>>> ----- Original Message -----
>>>> > If you are running under gt2 anything, I dont think you're going
>>>> > through the SGE provider, are you? So I would not expect logs from it.
>>>> > I think we have a problem here with some GT2 setting in the pool,
>>>> > Swift client, or environment (eg port range; GLOBUS_HOSTNAME, etc). Or
>>>> > an attributing that is causing bad RSL?
>>>> > - Mike
>>>> > > Still nothing. Are you running with gt2:gt2:sge or gt2:sge?
>>>> > > On Thu, 2011-06-30 at 17:30 -0500, Ketan Maheshwari wrote:
>>>> > > > That doesn't seem to have worked. You should change the log4j in
>>>> > > > swift/dist/swift*/etc.
>>>> > > > sorry, now done.
>>>> /home/ketan/osg-tg-effort/ranger-catsn/catsn-20110630-1722-15y2s6n6.log
>>>> > > > Ketan
>>>> > > _______________________________________________
>>>> > > Swift-devel mailing list
>>>> > > Swift-devel at ci.uchicago.edu
>>>> > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>>>> > Michael Wilde
>>>> > Computation Institute, University of Chicago
>>>> > Mathematics and Computer Science Division
>>>> > Argonne National Laboratory
>>>> Michael Wilde
>>> Ketan
>>> Michael Wilde
>> Ketan
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110630/b2020fc2/attachment.html>
