[Swift-devel] swift on ranger
    Sarah Kenny
    skenny at uchicago.edu
    Thu Jun 30 21:33:34 CDT 2011
i'm able to get jobs into the queue with this sites file:
config>
 <import file="sys.xml"/>
<import file="vdl-lib.xml"/>
<set name="username">
  <arg><vdl:new type="string" value="user"/></arg>
</set>
  <!-- RANGER @ tg-login.ranger.tacc.teragrid.org -->
  <pool handle="RANGER">
    <profile namespace="karajan" key="initialScore">1</profile>
    <profile namespace="karajan" key="jobThrottle">10</profile>
    <profile namespace="globus" key="project">TG-DBS080004N</profile>
    <profile namespace="globus" key="maxwalltime">240</profile>
    <profile namespace="globus" key="queue">normal</profile>
    <filesystem provider="gsiftp" url="gsiftp://
gridftp.ranger.tacc.teragrid.org"/>
    <execution provider="gt2" jobmanager="SGE" url="
gatekeeper.ranger.tacc.teragrid.org"/>
<workdirectory>/work/00043/tg457040/sidgrid_out/{username}</workdirectory>
  </pool>
</config>
using gt2 for the exec provider...but yeah, can't get in the queue with
coasters
On Thu, Jun 30, 2011 at 6:37 PM, Ketan Maheshwari <
ketancmaheshwari at gmail.com> wrote:
> I tried provider=gt2 and gt4 but get following:
> case: provider=gt2, jobManager="gt2:fork"
> RunID: 20110630-2018-sjjtfjs8
> Progress:
> Progress:  Stage in:1
> Invalid GSSCredentials
> Caused by:
> org.globus.cog.abstraction.impl.common.task.InvalidSecurityContextException:
> Caused by: GSSException: Invalid name provided [Caused by: [JGLOBUS-112]
> Malformed name, "=" missing in "fork"]
> Failed to transfer wrapper log from catsn-20110630-2018-sjjtfjs8/info/c on
> RANGER
> Caused by:
> Failed to transfer wrapper log from catsn-20110630-2018-sjjtfjs8/info/e on
> RANGER
> Progress:  Failed:1
> Exception in cat:
> Arguments: [data.txt]
> Host: RANGER
> Directory: catsn-20110630-2018-sjjtfjs8/jobs/e/cat-e1g55cck
> stderr.txt:
> stdout.txt:
> log is at :
> /home/ketan/osg-tg-effort/ranger-catsn/catsn-20110630-2033-l3zo296g.log
> no gram log was created.
> case: provider=gt4, jobManager="gt2:fork"
> RunID: 20110630-2019-tn0n27kb
> Progress:
> Progress:  Submitted:1
> Cannot submit job: The AXIS engine could not find a target service to
> invoke!  targetService is ManagedJobFactoryService
> Caused by:
> org.globus.cog.abstraction.impl.common.task.TaskSubmissionException: Cannot
> submit job: The AXIS engine could not find a target service to invoke!
> Caused by: The AXIS engine could not find a target service to invoke!
> Failed to transfer wrapper log from catsn-20110630-2019-tn0n27kb/info/5 on
> RANGER
> Caused by:
> the log is:
> /home/ketan/osg-tg-effort/ranger-catsn/catsn-20110630-2036-zcqs7td6.log
> On Thu, Jun 30, 2011 at 8:05 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
>> Can you send the Ranger-side GRAM log from the run, as well as a pointer
>> to the log and site file?
>> I meant, by the way, a non-coaster run with the GT2 provider and
>> jobmanager SGE.
>> A Condor-G test to both the fork and SGE jobmanagers would be helpful too.
>> - Mike
>> Mike, All,
>> gt2:fork works.
>> gt2:SGE doesn't, I get similar stage-in, submitted, submitted ... as with
>> gt2:gt2:SGE
>> On Thu, Jun 30, 2011 at 6:37 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
>>> Ketan,
>>> Can you try a single catsn job with just the GT2 provider, first to the
>>> Ranger fork job manager and then to the SGE jobmanager?
>>> - Mike
>>> ----- Original Message -----
>>> > If you are running under gt2 anything, I dont think you're going
>>> > through the SGE provider, are you? So I would not expect logs from it.
>>> > I think we have a problem here with some GT2 setting in the pool,
>>> > Swift client, or environment (eg port range; GLOBUS_HOSTNAME, etc). Or
>>> > an attributing that is causing bad RSL?
>>> > - Mike
>>> > > Still nothing. Are you running with gt2:gt2:sge or gt2:sge?
>>> > > On Thu, 2011-06-30 at 17:30 -0500, Ketan Maheshwari wrote:
>>> > > > That doesn't seem to have worked. You should change the log4j in
>>> > > >         swift/dist/swift*/etc.
>>> > > > sorry, now done.
>>> /home/ketan/osg-tg-effort/ranger-catsn/catsn-20110630-1722-15y2s6n6.log
>>> > > > Ketan
>>> > > _______________________________________________
>>> > > Swift-devel mailing list
>>> > > Swift-devel at ci.uchicago.edu
>>> > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>>> > Michael Wilde
>>> > Computation Institute, University of Chicago
>>> > Mathematics and Computer Science Division
>>> > Argonne National Laboratory
>>> Michael Wilde
>> Ketan
>> Michael Wilde
> Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110630/ae193c30/attachment.html>
