[Swift-devel] swift on ranger
Ketan Maheshwari ketancmaheshwari at gmail.com
Thu Jun 30 20:37:19 CDT 2011
I tried provider=gt2 and gt4 but get following:
case: provider=gt2, jobManager="gt2:fork"
RunID: 20110630-2018-sjjtfjs8
Progress:
Progress:  Stage in:1
Invalid GSSCredentials
Caused by:
org.globus.cog.abstraction.impl.common.task.InvalidSecurityContextException:
Caused by: GSSException: Invalid name provided [Caused by: [JGLOBUS-112]
Malformed name, "=" missing in "fork"]
Failed to transfer wrapper log from catsn-20110630-2018-sjjtfjs8/info/c on
RANGER
Caused by:
Failed to transfer wrapper log from catsn-20110630-2018-sjjtfjs8/info/e on
RANGER
Progress:  Failed:1
Exception in cat:
Arguments: [data.txt]
Host: RANGER
Directory: catsn-20110630-2018-sjjtfjs8/jobs/e/cat-e1g55cck
stderr.txt:
stdout.txt:
log is at :
/home/ketan/osg-tg-effort/ranger-catsn/catsn-20110630-2033-l3zo296g.log
no gram log was created.
case: provider=gt4, jobManager="gt2:fork"
RunID: 20110630-2019-tn0n27kb
Progress:
Progress:  Submitted:1
Cannot submit job: The AXIS engine could not find a target service to
invoke!  targetService is ManagedJobFactoryService
Caused by:
org.globus.cog.abstraction.impl.common.task.TaskSubmissionException: Cannot
submit job: The AXIS engine could not find a target service to invoke!
Caused by: The AXIS engine could not find a target service to invoke!
Failed to transfer wrapper log from catsn-20110630-2019-tn0n27kb/info/5 on
RANGER
Caused by:
the log is:
/home/ketan/osg-tg-effort/ranger-catsn/catsn-20110630-2036-zcqs7td6.log
On Thu, Jun 30, 2011 at 8:05 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> Can you send the Ranger-side GRAM log from the run, as well as a pointer to
> the log and site file?
> I meant, by the way, a non-coaster run with the GT2 provider and jobmanager
> SGE.
> A Condor-G test to both the fork and SGE jobmanagers would be helpful too.
> - Mike
> Mike, All,
> gt2:fork works.
> gt2:SGE doesn't, I get similar stage-in, submitted, submitted ... as with
> gt2:gt2:SGE
> On Thu, Jun 30, 2011 at 6:37 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
>> Ketan,
>> Can you try a single catsn job with just the GT2 provider, first to the
>> Ranger fork job manager and then to the SGE jobmanager?
>> - Mike
>> ----- Original Message -----
>> > If you are running under gt2 anything, I dont think you're going
>> > through the SGE provider, are you? So I would not expect logs from it.
>> > I think we have a problem here with some GT2 setting in the pool,
>> > Swift client, or environment (eg port range; GLOBUS_HOSTNAME, etc). Or
>> > an attributing that is causing bad RSL?
>> > - Mike
>> > > Still nothing. Are you running with gt2:gt2:sge or gt2:sge?
>> > > On Thu, 2011-06-30 at 17:30 -0500, Ketan Maheshwari wrote:
>> > > > That doesn't seem to have worked. You should change the log4j in
>> > > >         swift/dist/swift*/etc.
>> > > > sorry, now done.
>> /home/ketan/osg-tg-effort/ranger-catsn/catsn-20110630-1722-15y2s6n6.log
>> > > > Ketan
>> > > _______________________________________________
>> > > Swift-devel mailing list
>> > > Swift-devel at ci.uchicago.edu
>> > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>> > Michael Wilde
>> > Computation Institute, University of Chicago
>> > Mathematics and Computer Science Division
>> > Argonne National Laboratory
>> Michael Wilde
> Ketan
> Michael Wilde
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110630/2870d7d0/attachment.html>
