[Swift-devel] swift on ranger
    Michael Wilde
    wilde at mcs.anl.gov
    Thu Jun 30 20:05:03 CDT 2011
Can you send the Ranger-side GRAM log from the run, as well as a pointer to the log and site file?
I meant, by the way, a non-coaster run with the GT2 provider and jobmanager SGE.
A Condor-G test to both the fork and SGE jobmanagers would be helpful too.
- Mike
----- Original Message -----
Mike, All,
gt2:fork works.
gt2:SGE doesn't, I get similar stage-in, submitted, submitted ... as with gt2:gt2:SGE
On Thu, Jun 30, 2011 at 6:37 PM, Michael Wilde < wilde at mcs.anl.gov > wrote:
Ketan,
Can you try a single catsn job with just the GT2 provider, first to the Ranger fork job manager and then to the SGE jobmanager?
- Mike
> If you are running under gt2 anything, I dont think you're going
> through the SGE provider, are you? So I would not expect logs from it.
> I think we have a problem here with some GT2 setting in the pool,
> Swift client, or environment (eg port range; GLOBUS_HOSTNAME, etc). Or
> an attributing that is causing bad RSL?
> - Mike
> > Still nothing. Are you running with gt2:gt2:sge or gt2:sge?
> > On Thu, 2011-06-30 at 17:30 -0500, Ketan Maheshwari wrote:
> > > That doesn't seem to have worked. You should change the log4j in
> > > swift/dist/swift*/etc.
> > > sorry, now done.
> > > /home/ketan/osg-tg-effort/ranger-catsn/catsn-20110630-1722-15y2s6n6.log
> > > Ketan
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
Michael Wilde
Ketan
Michael Wilde
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110630/76c8006d/attachment.html>
