[Swift-devel] Swift unresponsive while using local provider.
Alberto Chavez
alberto_chavez at live.com
Fri Jun 17 18:55:26 CDT 2011
sites.template.xml is producing this error, as soon as I remove the file from the directory, the error goes away as well.These are the contents of such file:
<config> <pool handle="localhost"> <filesystem provider="local" /> <execution provider="coaster" jobmanager="local:local"/> <profile namespace="globus" key="internalHostname">127.0.0.1</profile> <profile namespace="karajan" key="jobthrottle">1000</profile> <profile namespace="karajan" key="initialScore">10000</profile> <profile namespace="globus" key="jobsPerNode">4</profile> <profile namespace="globus" key="slots">8</profile> <profile namespace="globus" key="maxTime">1000</profile> <profile namespace="globus" key="nodeGranularity">1</profile> <profile namespace="globus" key="maxNodes">4</profile> <workdirectory>/tmp</workdirectory> </pool></config>
-Alberto
> Subject: Re: [Swift-devel] Swift unresponsive while using local provider.
> From: hategan at mcs.anl.gov
> To: davidkelly999 at gmail.com
> Date: Fri, 17 Jun 2011 12:56:25 -0700
> CC: swift-devel at ci.uchicago.edu
> do "jstack -l <pid_of_swift_java_process>" whenever it happens and send
> the output.
> On Fri, 2011-06-17 at 14:48 -0500, David Kelly wrote:
> > I saw similar things on my laptop (4 gb ram) this weekend when I was
> > testing the galaxy demo scripts using the local provider. I was using
> > trunk. In the output I would see things like "no activity for 10s" and
> > it just would sit there and do nothing until I manually killed it. But
> > most of the time it would work fine. I wrote a little shell script
> > that would repeatedly run it until it hung. Then I was talking to Jon
> > about this and he saw something similar with his montage work. He
> > thought it might be related to a configuration issue - that either
> > wrapper.parameter.mode=files or status.mode=provider should be set.
> > I can send my scripts as well if you need some help in tracking this
> > down.
> > David
> > On Fri, Jun 17, 2011 at 2:38 PM, Michael Wilde <wilde at mcs.anl.gov>
> > wrote:
> > Alberto, how long are you letting it run for, and under what
> > environment? if you are running on your laptop, how much RAM
> > do you have? Its possible that you are seeing paging delays
> > if you are running the Swift Java app with too little memory.
> > Also, are you running trunk or 0.92.1? You should compare the
> > two.
> > Its *possible* that this simple test is hanging under recent
> > trunk mods, but its more likely that this is some kind of
> > resource shortage.
> > Can you run this on one of the Swift lab machines bridled or
> > communcado, or better yet on the MCS compute servers, or a
> > PADS worker node (which you can get with qsub -I on pads)?
> > Look at Swift under the "top" command to see if Swift is
> > running and slow, or is hung.
> > Stop by and we can discuss in more detail.
> > - Mike
> > ______________________________________________________________
> > When I run the following SwiftScript using suite.sh,
> > the report shows an odd behavior, most of the time it
> > times out, but once in a while it passes, however this
> > outcome is completely random, since sometimes that
> > test has passed 3 times in a row, and all of the
> > sudden it fails.
> > This is my script:
> > type messagefile;
> > app (messagefile t) greeting (string s[]) {
> > echo s[0] s[1] s[2] stdout=@filename(t);
> > messagefile outfile <"q5out.txt">;
> > string words[] = ["how","are","you"];
> > outfile = greeting(words);
> > Swift.properties contents:
> > $ cat swift.properties
> > wrapperlog.always.transfer=true
> > sitedir.keep=true
> > execution.retries=0
> > lazy.errors=false
> > use.provider.staging=false
> > provider.staging.pin.swiftfiles=false
> > Sites.template.xml contents:
> > $ cat sites.template.xml
> > <config>
> > </pool>
> > </config>
> > -Alberto
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
> > Michael Wilde
> > Computation Institute, University of Chicago
> > Mathematics and Computer Science Division
> > Argonne National Laboratory
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110617/9c8bf586/attachment.html>
