[Swift-devel] Swift unresponsive while using local provider.
Alberto Chavez alberto_chavez at live.com
Fri Jun 17 15:55:32 CDT 2011
I just checked the report for Bridled and Communicado and the test failed in both , with the same output:type messagefile;
app (messagefile t) greeting (string s[]) {
	echo s[0] s[1] s[2] stdout=@filename(t);
messagefile outfile <"q5out.txt">;
string words[] = ["how","are","you"];
outfile = greeting(words);--------------------------------------------------------Swift svn swift-r4629 cog-r3164
RunID: 20110617-1525-c7tjr1mg
Progress:  time: Fri, 17 Jun 2011 15:25:25 -0500
No events in 10s.
Progress:  time: Fri, 17 Jun 2011 15:25:55 -0500------------------------------------------------------------------------------------------------------------------
> Subject: Re: [Swift-devel] Swift unresponsive while using local provider.
> From: hategan at mcs.anl.gov
> To: wilde at mcs.anl.gov
> Date: Fri, 17 Jun 2011 13:08:32 -0700
> CC: alan.chavez at live.com.mx; swift-devel at ci.uchicago.edu
> On Fri, 2011-06-17 at 15:03 -0500, Michael Wilde wrote:
> > This would be a great thing to build into the test suite for any test run that the suite is about to cancel for exceeding its max run time: capture the stack trace, so that if its a deadlock, we can do some diagnosis right form the test results.
> > Can we add some Swift commands to dump Swifts thread/future status as well?
> The hang checker already does that, but there is a class of deadlocks
> that has no open futures.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110617/e5d54cc6/attachment.html>
