[Swift-devel] Swift unresponsive while using local provider.
    Michael Wilde
    wilde at mcs.anl.gov
    Fri Jun 17 14:54:32 CDT 2011
Yes, please post the scripts, David. This sounds like trunk instability.
Is your trunk working copy and build up to date?
Does that same script run quickly every time under 0.92.1?
- Mike
----- Original Message -----
I saw similar things on my laptop (4 gb ram) this weekend when I was testing the galaxy demo scripts using the local provider. I was using trunk. In the output I would see things like "no activity for 10s" and it just would sit there and do nothing until I manually killed it. But most of the time it would work fine. I wrote a little shell script that would repeatedly run it until it hung. Then I was talking to Jon about this and he saw something similar with his montage work. He thought it might be related to a configuration issue - that either wrapper.parameter.mode=files or status.mode=provider should be set.
I can send my scripts as well if you need some help in tracking this down.
David
On Fri, Jun 17, 2011 at 2:38 PM, Michael Wilde < wilde at mcs.anl.gov > wrote:
Alberto, how long are you letting it run for, and under what environment? if you are running on your laptop, how much RAM do you have? Its possible that you are seeing paging delays if you are running the Swift Java app with too little memory.
Also, are you running trunk or 0.92.1? You should compare the two.
Its *possible* that this simple test is hanging under recent trunk mods, but its more likely that this is some kind of resource shortage.
Can you run this on one of the Swift lab machines bridled or communcado, or better yet on the MCS compute servers, or a PADS worker node (which you can get with qsub -I on pads)?
Look at Swift under the "top" command to see if Swift is running and slow, or is hung.
Stop by and we can discuss in more detail.
- Mike
When I run the following SwiftScript using suite.sh, the report shows an odd behavior, most of the time it times out, but once in a while it passes, however this outcome is completely random, since sometimes that test has passed 3 times in a row, and all of the sudden it fails.
This is my script:
type messagefile;
app (messagefile t) greeting (string s[]) {
echo s[0] s[1] s[2] stdout=@filename(t);
messagefile outfile <"q5out.txt">;
string words[] = ["how","are","you"];
outfile = greeting(words);
Swift.properties contents:
$ cat swift.properties
wrapperlog.always.transfer=true
sitedir.keep=true
execution.retries=0
lazy.errors=false
use.provider.staging=false
provider.staging.pin.swiftfiles=false
Sites.template.xml contents:
$ cat sites.template.xml
<config>
<pool handle="localhost">
<filesystem provider="local" />
<execution provider="coaster" jobmanager="local:local"/>
<profile namespace="globus" key="internalHostname">127.0.0.1</profile>
<profile namespace="karajan" key="jobthrottle">1000</profile>
<profile namespace="karajan" key="initialScore">10000</profile>
<profile namespace="globus" key="jobsPerNode">4</profile>
<profile namespace="globus" key="slots">8</profile>
<profile namespace="globus" key="maxTime">1000</profile>
<profile namespace="globus" key="nodeGranularity">1</profile>
<profile namespace="globus" key="maxNodes">4</profile>
<workdirectory>/tmp</workdirectory>
</pool>
</config>
-Alberto
Swift-devel mailing list
Swift-devel at ci.uchicago.edu
http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
Michael Wilde
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110617/b49abd82/attachment.html>
