[Swift-devel] Swift unresponsive while using local provider.
David Kelly davidkelly999 at gmail.com
Fri Jun 17 14:48:05 CDT 2011
I saw similar things on my laptop (4 gb ram) this weekend when I was testing
the galaxy demo scripts using the local provider. I was using trunk. In the
output I would see things like "no activity for 10s" and it just would sit
there and do nothing until I manually killed it. But most of the time it
would work fine. I wrote a little shell script that would repeatedly run it
until it hung. Then I was talking to Jon about this and he saw something
similar with his montage work. He thought it might be related to a
configuration issue - that either wrapper.parameter.mode=files or
status.mode=provider should be set.
I can send my scripts as well if you need some help in tracking this down.
David
On Fri, Jun 17, 2011 at 2:38 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> Alberto,  how long are you letting it run for, and under what environment?
>  if you are running on your laptop, how much RAM do you have?  Its possible
> that you are seeing paging delays if you are running the Swift Java app with
> too little memory.
> Also, are you running trunk or 0.92.1?  You should compare the two.
> Its *possible* that this simple test is hanging under recent trunk mods,
> but its more likely that this is some kind of resource shortage.
> Can you run this on one of the Swift lab machines bridled or communcado, or
> better yet on the MCS compute servers, or a PADS worker node (which you can
> get with qsub -I on pads)?
> Look at Swift under the "top" command to see if Swift is running and slow,
> or is hung.
> Stop by and we can discuss in more detail.
> - Mike
>  When I run the following SwiftScript using suite.sh, the report shows an
> odd behavior, most of the time it times out, but once in a while it passes,
> however this outcome is completely random, since sometimes that test has
> passed 3 times in a row, and all of the sudden it fails.
> This is my script:
> type messagefile;
> app (messagefile t) greeting (string s[]) {
>         echo s[0] s[1] s[2] stdout=@filename(t);
> messagefile outfile <"q5out.txt">;
> string words[] = ["how","are","you"];
> outfile = greeting(words);
> Swift.properties contents:
> $ cat swift.properties
> wrapperlog.always.transfer=true
> sitedir.keep=true
> execution.retries=0
> lazy.errors=false
> use.provider.staging=false
> provider.staging.pin.swiftfiles=false
> Sites.template.xml contents:
> $ cat sites.template.xml
> <config>
>   <pool handle="localhost">
>     <filesystem provider="local" />
>     <execution provider="coaster" jobmanager="local:local"/>
>     <profile namespace="globus"
> key="internalHostname">127.0.0.1</profile>
>     <profile namespace="karajan"  key="jobthrottle">1000</profile>
>     <profile namespace="karajan"  key="initialScore">10000</profile>
>     <profile namespace="globus"   key="jobsPerNode">4</profile>
>     <profile namespace="globus"   key="slots">8</profile>
>     <profile namespace="globus"   key="maxTime">1000</profile>
>     <profile namespace="globus"   key="nodeGranularity">1</profile>
>     <profile namespace="globus"   key="maxNodes">4</profile>
>     <workdirectory>/tmp</workdirectory>
>   </pool>
> </config>
> -Alberto
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110617/7f6a4051/attachment.html>
