[Swift-devel] Swift unresponsive while using local provider.
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri Jun 17 14:56:25 CDT 2011
do "jstack -l <pid_of_swift_java_process>" whenever it happens and send
the output.
On Fri, 2011-06-17 at 14:48 -0500, David Kelly wrote:
> I saw similar things on my laptop (4 gb ram) this weekend when I was
> testing the galaxy demo scripts using the local provider. I was using
> trunk. In the output I would see things like "no activity for 10s" and
> it just would sit there and do nothing until I manually killed it. But
> most of the time it would work fine. I wrote a little shell script
> that would repeatedly run it until it hung. Then I was talking to Jon
> about this and he saw something similar with his montage work. He
> thought it might be related to a configuration issue - that either
> wrapper.parameter.mode=files or status.mode=provider should be set.
> I can send my scripts as well if you need some help in tracking this
> down.
> David
> On Fri, Jun 17, 2011 at 2:38 PM, Michael Wilde <wilde at mcs.anl.gov>
> wrote:
>         Alberto,  how long are you letting it run for, and under what
>         environment?  if you are running on your laptop, how much RAM
>         do you have?  Its possible that you are seeing paging delays
>         if you are running the Swift Java app with too little memory.
>         Also, are you running trunk or 0.92.1?  You should compare the
>         two.
>         Its *possible* that this simple test is hanging under recent
>         trunk mods, but its more likely that this is some kind of
>         resource shortage.
>         Can you run this on one of the Swift lab machines bridled or
>         communcado, or better yet on the MCS compute servers, or a
>         PADS worker node (which you can get with qsub -I on pads)?
>         Look at Swift under the "top" command to see if Swift is
>         running and slow, or is hung.
>         Stop by and we can discuss in more detail.
>         - Mike
>         ______________________________________________________________
>                 When I run the following SwiftScript using suite.sh,
>                 the report shows an odd behavior, most of the time it
>                 times out, but once in a while it passes, however this
>                 outcome is completely random, since sometimes that
>                 test has passed 3 times in a row, and all of the
>                 sudden it fails.
>                 This is my script:
>                 type messagefile;
>                 app (messagefile t) greeting (string s[]) {
>                         echo s[0] s[1] s[2] stdout=@filename(t);
>                 messagefile outfile <"q5out.txt">;
>                 string words[] = ["how","are","you"];
>                 outfile = greeting(words);
>                 Swift.properties contents:
>                 $ cat swift.properties
>                 wrapperlog.always.transfer=true
>                 sitedir.keep=true
>                 execution.retries=0
>                 lazy.errors=false
>                 use.provider.staging=false
>                 provider.staging.pin.swiftfiles=false
>                 Sites.template.xml contents:
>                 $ cat sites.template.xml
>                 <config>
>                   <pool handle="localhost">
>                     <filesystem provider="local" />
>                     <execution provider="coaster"
>                 jobmanager="local:local"/>
>                     <profile namespace="globus"
>                 key="internalHostname">127.0.0.1</profile>
>                     <profile namespace="karajan"
>                  key="jobthrottle">1000</profile>
>                  key="initialScore">10000</profile>
>                 key="jobsPerNode">4</profile>
>                 key="slots">8</profile>
>                 key="maxTime">1000</profile>
>                 key="nodeGranularity">1</profile>
>                 key="maxNodes">4</profile>
>                     <workdirectory>/tmp</workdirectory>
>                   </pool>
>                 </config>
>                 -Alberto
>                 Swift-devel mailing list
>                 Swift-devel at ci.uchicago.edu
>                 http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
>         Michael Wilde
>         Computation Institute, University of Chicago
>         Mathematics and Computer Science Division
>         Argonne National Laboratory
