[Swift-devel] Swift unresponsive while using local provider.
Michael Wilde
wilde at mcs.anl.gov
Fri Jun 17 14:38:53 CDT 2011
Alberto, how long are you letting it run for, and under what environment? if you are running on your laptop, how much RAM do you have? Its possible that you are seeing paging delays if you are running the Swift Java app with too little memory.
Also, are you running trunk or 0.92.1? You should compare the two.
Its *possible* that this simple test is hanging under recent trunk mods, but its more likely that this is some kind of resource shortage.
Can you run this on one of the Swift lab machines bridled or communcado, or better yet on the MCS compute servers, or a PADS worker node (which you can get with qsub -I on pads)?
Look at Swift under the "top" command to see if Swift is running and slow, or is hung.
Stop by and we can discuss in more detail.
- Mike
----- Original Message -----
When I run the following SwiftScript using suite.sh, the report shows an odd behavior, most of the time it times out, but once in a while it passes, however this outcome is completely random, since sometimes that test has passed 3 times in a row, and all of the sudden it fails.
This is my script:
type messagefile;
app (messagefile t) greeting (string s[]) {
echo s[0] s[1] s[2] stdout=@filename(t);
messagefile outfile <"q5out.txt">;
string words[] = ["how","are","you"];
outfile = greeting(words);
Swift.properties contents:
$ cat swift.properties
wrapperlog.always.transfer=true
sitedir.keep=true
execution.retries=0
lazy.errors=false
status.mode=provider
use.provider.staging=false
provider.staging.pin.swiftfiles=false
Sites.template.xml contents:
$ cat sites.template.xml
<config>
<pool handle="localhost">
<filesystem provider="local" />
<execution provider="coaster" jobmanager="local:local"/>
<profile namespace="globus" key="internalHostname">127.0.0.1</profile>
<profile namespace="karajan" key="jobthrottle">1000</profile>
<profile namespace="karajan" key="initialScore">10000</profile>
<profile namespace="globus" key="jobsPerNode">4</profile>
<profile namespace="globus" key="slots">8</profile>
<profile namespace="globus" key="maxTime">1000</profile>
<profile namespace="globus" key="nodeGranularity">1</profile>
<profile namespace="globus" key="maxNodes">4</profile>
<workdirectory>/tmp</workdirectory>
</pool>
</config>
-Alberto
Swift-devel mailing list
Swift-devel at ci.uchicago.edu
http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110617/438f8072/attachment.html>
