[Swift-devel] java.lang.IncompatibleClassChangeError when using Trunk
Justin M Wozniak wozniak at mcs.anl.gov
Mon Jun 13 17:00:37 CDT 2011
I think you may need to do an ant clean.
 	Justin
On Mon, 13 Jun 2011, ketan wrote:
> Hello,
> I am getting this exception using trunk:
> Uncaught exception: java.lang.IncompatibleClassChangeError: Expecting
> non-static method
> org.globus.cog.util.TextFileLoader.loadFromResource(Ljava/lang/String;)Ljava/lang/String;
> in import @ vdl-sc.k, line: 5
> java.lang.IncompatibleClassChangeError: Expecting non-static method
>    at org.globus.cog.karajan.parser.Grammar.load(Grammar.java:26)
>    at org.globus.cog.karajan.parser.Grammar.<init>(Grammar.java:22)
>    at org.globus.cog.karajan.parser.Parser.<init>(Parser.java:40)
>    at
> org.globus.cog.karajan.translator.KarajanTranslator.getParser(KarajanTranslator.java:33)
>    at
> org.globus.cog.karajan.translator.KarajanTranslator.translate(KarajanTranslator.java:58)
>    at
> org.globus.cog.karajan.workflow.nodes.Include.includeFile(Include.java:263)
>    at
> org.globus.cog.karajan.workflow.nodes.Include.checkArgs(Include.java:61)
>    at org.globus.cog.karajan.workflow.nodes.Include.post(Include.java:73)
>    at
> org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:29)
>    at
> org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:20)
>    at
> org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
>    at
> org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:139)
>    at
> org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:197)
>    at
> org.globus.cog.karajan.workflow.FlowElementWrapper.start(FlowElementWrapper.java:227)
>    at
> org.globus.cog.karajan.workflow.events.EventBus.start(EventBus.java:104)
>    at
> org.globus.cog.karajan.workflow.events.EventTargetPair.run(EventTargetPair.java:40)
>    at
> java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
>    at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
>    at java.util.concurrent.FutureTask.run(FutureTask.java:138)
>    at
> java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
>    at
> java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
>    at java.lang.Thread.run(Thread.java:662)
> Exception is: java.lang.IncompatibleClassChangeError: Expecting non-static
> method
> Near Karajan line: import @ vdl-sc.k, line: 5
> Execution failed:
> non-static method
> Java is:
> [bridled:site_gen]$ java -version
> java version "1.6.0_23"
> Java(TM) SE Runtime Environment (build 1.6.0_23-b05)
> Java HotSpot(TM) 64-Bit Server VM (build 19.0-b09, mixed mode)
> Attached are the Swift scripts and the sites.xml files.
> Ketan
Justin M Wozniak
