[Swift-devel] java.lang.IncompatibleClassChangeError when using	Trunk
    ketan
    ketancmaheshwari at gmail.com
    Mon Jun 13 17:23:21 CDT 2011
That works, thanks.
On 6/13/11 5:00 PM, Justin M Wozniak wrote:
> I think you may need to do an ant clean.
>     Justin
> On Mon, 13 Jun 2011, ketan wrote:
>> Hello,
>> I am getting this exception using trunk:
>> Uncaught exception: java.lang.IncompatibleClassChangeError: Expecting
>> non-static method
>> org.globus.cog.util.TextFileLoader.loadFromResource(Ljava/lang/String;)Ljava/lang/String;
>> in import @ vdl-sc.k, line: 5
>> java.lang.IncompatibleClassChangeError: Expecting non-static method
>>    at org.globus.cog.karajan.parser.Grammar.load(Grammar.java:26)
>>    at org.globus.cog.karajan.parser.Grammar.<init>(Grammar.java:22)
>>    at org.globus.cog.karajan.parser.Parser.<init>(Parser.java:40)
>>    at
>> org.globus.cog.karajan.translator.KarajanTranslator.getParser(KarajanTranslator.java:33)
>>    at
>> org.globus.cog.karajan.translator.KarajanTranslator.translate(KarajanTranslator.java:58)
>>    at
>> org.globus.cog.karajan.workflow.nodes.Include.includeFile(Include.java:263)
>>    at
>> org.globus.cog.karajan.workflow.nodes.Include.checkArgs(Include.java:61)
>>    at
>> org.globus.cog.karajan.workflow.nodes.Include.post(Include.java:73)
>>    at
>> org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:29)
>>    at
>> org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:20)
>>    at
>> org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
>>    at
>> org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:139)
>>    at
>> org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:197)
>>    at
>> org.globus.cog.karajan.workflow.FlowElementWrapper.start(FlowElementWrapper.java:227)
>>    at
>> org.globus.cog.karajan.workflow.events.EventBus.start(EventBus.java:104)
>>    at
>> org.globus.cog.karajan.workflow.events.EventTargetPair.run(EventTargetPair.java:40)
>>    at
>> java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
>>    at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
>>    at java.util.concurrent.FutureTask.run(FutureTask.java:138)
>>    at
>> java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
>>    at
>> java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
>>    at java.lang.Thread.run(Thread.java:662)
>> Exception is: java.lang.IncompatibleClassChangeError: Expecting
>> non-static method
>> Near Karajan line: import @ vdl-sc.k, line: 5
>> Execution failed:
>> Java is:
>> [bridled:site_gen]$ java -version
>> java version "1.6.0_23"
>> Java(TM) SE Runtime Environment (build 1.6.0_23-b05)
>> Java HotSpot(TM) 64-Bit Server VM (build 19.0-b09, mixed mode)
>> Attached are the Swift scripts and the sites.xml files.
>> Ketan
