[Swift-devel] java.lang.IncompatibleClassChangeError when using	Trunk
    ketan
    ketancmaheshwari at gmail.com
    Mon Jun 13 16:47:19 CDT 2011
Hello,
I am getting this exception using trunk:
Uncaught exception: java.lang.IncompatibleClassChangeError: Expecting
non-static method
org.globus.cog.util.TextFileLoader.loadFromResource(Ljava/lang/String;)Ljava/lang/String;
in import @ vdl-sc.k, line: 5
java.lang.IncompatibleClassChangeError: Expecting non-static method
     at org.globus.cog.karajan.parser.Grammar.load(Grammar.java:26)
     at org.globus.cog.karajan.parser.Grammar.<init>(Grammar.java:22)
     at org.globus.cog.karajan.parser.Parser.<init>(Parser.java:40)
     at
org.globus.cog.karajan.translator.KarajanTranslator.getParser(KarajanTranslator.java:33)
     at
org.globus.cog.karajan.translator.KarajanTranslator.translate(KarajanTranslator.java:58)
     at
org.globus.cog.karajan.workflow.nodes.Include.includeFile(Include.java:263)
     at
org.globus.cog.karajan.workflow.nodes.Include.checkArgs(Include.java:61)
     at org.globus.cog.karajan.workflow.nodes.Include.post(Include.java:73)
     at
org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:29)
     at
org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:20)
     at
org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
     at
org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:139)
     at
org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:197)
     at
org.globus.cog.karajan.workflow.FlowElementWrapper.start(FlowElementWrapper.java:227)
     at
org.globus.cog.karajan.workflow.events.EventBus.start(EventBus.java:104)
     at
org.globus.cog.karajan.workflow.events.EventTargetPair.run(EventTargetPair.java:40)
     at
java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
     at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
     at java.util.concurrent.FutureTask.run(FutureTask.java:138)
     at
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
     at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
     at java.lang.Thread.run(Thread.java:662)
Exception is: java.lang.IncompatibleClassChangeError: Expecting
non-static method
Near Karajan line: import @ vdl-sc.k, line: 5
Execution failed:
Java is:
[bridled:site_gen]$ java -version
java version "1.6.0_23"
Java(TM) SE Runtime Environment (build 1.6.0_23-b05)
Java HotSpot(TM) 64-Bit Server VM (build 19.0-b09, mixed mode)
Attached are the Swift scripts and the sites.xml files.
Ketan
Type: text/xml
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110613/649b3a19/attachment.xml>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110613/649b3a19/attachment.ksh>
