[Swift-devel] Re: Work with Justin on performance plotting
Jonathan Monette jonmon at utexas.edu
Mon Jun 13 15:44:01 CDT 2011
Also, looking at the first command in the README for log-processing "make -f libexec/log-processing/makefile.implicit swift-run.plot.norm" can't we take that out and just show users how to use the perl script that normalizes the logs to a time.  I don't think running the makefile to call this perl script is very useful in this case and we can cut out the middle man.
On Jun 13, 2011, at 10:53 AM, Justin M Wozniak wrote:
> Hello
> 	I don't have much to add other than the READMEs and link below. I have tested and documented only a few plots; let's continue to add to the README and build up some additional good use cases.
> 	Justin
> On Thu, 9 Jun 2011, ketan wrote:
>> Jon,
>> To give you heads up, the performance plotting tools are located in trunk at: swift/libexec/log-processing
>> The Readme has some information on setup and generating plots.
>> More follows on the tools I added.
>> Ketan
>> On 6/9/11 1:58 PM, Jonathan Monette wrote:
>>> Sure, I can work on this.  Whenever Justin is ready and has time we can meet or he can point me to what works.
>>> On Jun 9, 2011, at 1:50 PM, Michael Wilde wrote:
>>>> Hi Jon,
>>>> After discussing this with Justin earlier in the week, I suggested that you work with Justin on testing and continuing to enhance his new version of the Swift performance plotting package.
>>>> Can you work with Justin to locate the package, try the latest, review and update the documents, and start enhancing it under Justin's guidance to get the plots you need for Montage?
>>>> Ketan, I know that you have similar needs and have worked with Justin in the past on these (or similar) tools.  Can you serve as an early user of the tools and give Jon feedback for further enhancement?
>>>> Lets do all discussion of the topic on swift-devel (including the handoff from you, Justin, explaining the state of development and where everything is located).
>>>> Thanks,
>>>> Mike
>>>> Michael Wilde
>>>> Computation Institute, University of Chicago
>>>> Mathematics and Computer Science Division
>>>> Argonne National Laboratory
> Justin M Wozniak
