[Swift-devel] catsn on beagle
Jonathan S Monette
jonmon at utexas.edu
Tue Jun 7 12:28:27 CDT 2011
-DGLOBUS_HOSTNAME is getting it's value from $HOSTNAME which for some reason
has (none) appended to the end. It doesn't matter if I am on
login1.beagle.ci.uchicago.edu or login2.beagle.ci.uchicago.edu, (none) is
there. I already emailed support-beagle inquiring why it shows up. Is
there a way to set the value for -DGLOBUS_HOSTNAME in the sites.xml file or
something until the problem is resolved? Right now I have to override the
variable manually but if I can just add a line to my sites file that would
be better.
On Tue, Jun 7, 2011 at 12:16 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> On Sat, 2011-06-04 at 11:50 -0500, Jonathan S Monette wrote:
> > Hello,
> > I am trying to run the catsn test on beagle using the files in
> > ~ketan/catsn. I have copied over this directory over to my home
> > directory and I believe I set it up correctly. I did module load
> > swift and the ran run.sh that was in this directory. I get this
> > error.
> > /soft/swift/0.92/bin/swift: eval: line 152: syntax error near
> > unexpected token `('
> > /soft/swift/0.92/bin/swift: eval: line 152: `java -Xmx8192M
> > -Djava.endorsed.dirs=/soft/swift/0.92/bin/../lib/endorsed -DUID=1881
> > -DGLOBUS_HOSTNAME=login2.beagle.ci.uchicago.edu.(none)
> What's the "(none)" in there and where is it coming from?
Any intelligent fool can make things bigger and more complex... It takes a
touch of genius - and a lot of courage to move in the opposite direction.
- Albert Einstein
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110607/6d1cb126/attachment.html>
