[Swift-devel] catsn on beagle
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Jun  7 12:34:00 CDT 2011
You could filter out the "(none)" part in your .profile.
On Tue, 2011-06-07 at 12:28 -0500, Jonathan S Monette wrote:
> -DGLOBUS_HOSTNAME is getting it's value from $HOSTNAME which for some
> reason has (none) appended to the end.  It doesn't matter if I am on
> login1.beagle.ci.uchicago.edu or login2.beagle.ci.uchicago.edu, (none)
> is there.  I already emailed support-beagle inquiring why it shows
> up.  Is there a way to set the value for -DGLOBUS_HOSTNAME in the
> sites.xml file or something until the problem is resolved?  Right now
> I have to override the variable manually but if I can just add a line
> to my sites file that would be better.
> On Tue, Jun 7, 2011 at 12:16 PM, Mihael Hategan <hategan at mcs.anl.gov>
> wrote:
>         On Sat, 2011-06-04 at 11:50 -0500, Jonathan S Monette wrote:
>         > Hello,
>         >    I am trying to run the catsn test on beagle using the
>         files in
>         > ~ketan/catsn.  I have copied over this directory over to my
>         home
>         > directory and I believe I set it up correctly.  I did module
>         load
>         > swift and the ran run.sh that was in this directory.  I get
>         this
>         > error.
>         > /soft/swift/0.92/bin/swift: eval: line 152: syntax error
>         near
>         > unexpected token `('
>         > /soft/swift/0.92/bin/swift: eval: line 152: `java -Xmx8192M
>         > -Djava.endorsed.dirs=/soft/swift/0.92/bin/../lib/endorsed
>         -DUID=1881
>         > -DGLOBUS_HOSTNAME=login2.beagle.ci.uchicago.edu.(none)
>         What's the "(none)" in there and where is it coming from?
> Any intelligent fool can make things bigger and more complex... It
> takes a touch of genius - and a lot of courage to move in the opposite
> direction.
> - Albert Einstein
